Results 1 to 4 of 4
Thread: 1995 540i engine swap into 1993 525i car
    Mar 2019
    Houston, Texas
    88 535i
    Hey everyone! I’m an e28 guy but....
    I just got the opportunity to purchase an e34 540i with a bad body but solid drive train and a 525i with a great body and interior but with a bad engine( it knocks).
    I was wondering how hard swapping the v8 into the better car would be? Or if it would be possible swapping the v8 into any other e34?
    Since I’ll actually have both cars to get all of the parts from, I figured it would be “plug and play” more or less.
    Or should I just pass?
    Thanks!
    Jan 2015
    Tempe, AZ
    1995 525i/5
    It's quite a lot of work to swap a V8 into a straight-6 car. The brake booster is located in a different place on the V8 cars (close to the headlight), all the engine bay brackets for the reservoirs and whatnot are different, the wiring is all different, the ABS module location and brake lines are different, etc.
    I pondered the same thing with my 525it, and ultimately decided that it would be easier to get a 530it (small V8) and swap that to a M60B44 than it would be to try to make that work in the 525it.
    1995 525i 5-speed - Thread
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    NW suburban Chicago
    hiss by my window
    More work than it is worth in my opinion. By the time you are finished you'll wish you had; A, Just bought a decent 540 to begin with. B, replaced the 525 motor with another 2.5. **
    The V-8 brake set-up alone is a nightmare.
    ** I have a good 525 short block you can buy for $200
  1. Official 530i to 540i engine swap thread
    By Antrieb in forum 1988 - 1996 (E34)
    Last Post: 10-28-2015, 07:19 PM
  2. Replies: 46
    Last Post: 09-23-2009, 09:26 AM
  3. 1995 320i Engine Swap: NEED HELP
    By Sylvester22 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-11-2007, 10:18 PM
  4. 89 M3 doing 540i engine swap, Can It Be Done And How Much???
    By StupidFastM3 in forum 1987 - 1991 M3 (E30)
    Last Post: 07-30-2005, 06:23 PM
  5. 1995 M3 engine swap to 96 3.2L - anything to remember?
    By AaronM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-24-2002, 05:08 AM
