Results 1 to 5 of 5
Thread: Preventives for N55
    Jun 2019
    Greater Seattle
    2015 M235i, 2018 M3
    Preventives for N55
    As a 2015 M235i owner, I just wanted to see what others can recommend for a preventive swap out for new parts so that I don't need to be negatively surprised.
    Which part in the N55/F80 would you put as high priority to replace if the car is above 40K miles?
    I have replaced:
    - all brake pads
    - front rotors
    - going to replace front hub assembly + bearings this weekend.
    Are the VANOS seals as troublesome as the M54B30 where a new replacement is recommended after 40K miles ?
    Please chime in.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the General BMW Discussion sub-forum.
    88M3 AW 43k miles Project FS
    FL
    are slow.
    Oil and filter change every 7k miles instead of the normal 15k miles. BMW is crazy for saying 15k is the interval.
    Are you auto or manual? Would be wise to change the transmission fluid at 40-50k miles.
    -Dr. Seuss
    Jun 2019
    Greater Seattle
    2015 M235i, 2018 M3
    Mine is automatic transmission ZF 8HP
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The fluid and filter should be changed every 50k miles. Btw, changing the fluid really changes about 60% of the fluid as the remaining fluid is in the torque converter.
  1. Acne Prevention Solution?
    By mace in forum Off-Topic
    Last Post: 06-29-2002, 02:27 AM
  2. preventative radiator replacement
    By fourfa in forum 1992 - 1999 M3 (E36)
    Last Post: 06-11-2002, 02:35 PM
  3. Preventive maintenance for everyone.
    By UD///M in forum 1992 - 1999 M3 (E36)
    Last Post: 10-14-2001, 09:45 PM
  4. How can I prevent my superwhite bulbs burning out?
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 10-14-2001, 02:37 PM
  5. How to prevent miss shift?
    By DINAN COSMOS in forum 1992 - 1999 M3 (E36)
    Last Post: 08-21-2001, 11:49 AM
