Results 1 to 4 of 4
Thread: EWS Difficulty (3 posts combined)
    May 2019
    Spicewood, Tx
    2019 X3 M40i, 2000 528i
    I have a 2000 528i with the strangest EWS. If I want it to start it I have to remove the connector and plug it back in to get it to crank. I recently took it apart and was checking continuity from the ring antenna to the EWS at the board. At this point it would not crank. While I was doing this, I had the key all the way on, and I heard and felt the EWS relay click. I tried it and it started right up. After that, it started 10 to 20 times all day. The next day, back to no crank. Has anyone ever ran into this? I'm going to replace the EWS just to be done with the problem, but I wandered if this is a problem someone else has ran into?
    May 2019
    Spicewood, Tx
    Outlet coolant temp sensor
    I have a code for the "outlet coolant temp sensor ". I'm not sure where it's at. Would someone point me in the right direction? Thanks.
    May 2019
    Spicewood, Tx
    MAF Sensor
    My 2000 528i is throwing code for o2 sensors. This was happening after I drove it for a couple miles. I finally found one of the problems. Whenever I would tap the MAF sensor it would almost stall and the code would come back for the o2 sensors. Should I replace the o2 sensors and the MAF together? Or is the MAF causing the o2 to momentarily malfunction? I appreciate the advice.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    X3, saw your post the other day about not knowing how/where to post. The Hangout (above) isn't the place.
    Your general questions about repairs, etc go in this sub-forum.
  1. Anyone need S52 EWS/SAP/post-cat O2 delete? (NorCal)
    By gpeterson in forum California sponsored by Avus Autosport
    Last Post: 02-29-2016, 07:40 PM
  2. Replies: 24
    Last Post: 02-19-2015, 12:14 PM
  3. M3 96-99 OBD2 DME with EWS, SAP, and post-cat O2 delete
    By gpeterson in forum Engines, Performance Parts & Software
    Last Post: 03-03-2014, 03:23 PM
  4. Replies: 0
    Last Post: 01-07-2009, 05:10 PM
  5. Sorry for cross posting, EWS issue inside.
    By enyrgee in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-25-2008, 10:42 AM
