Results 1 to 10 of 10
Thread: 95' M3 Overheating issues.
    May 2018
    Portland
    95’ M3
    Recently swapped an S50 back into an M3 and I'm having the time of my life figuring out why it's overheating.
    The engine never overheated before I pulled it, ever.
    So far I have gone through 3 radiators, 2 thermostats, a new water pump, and 2 expansion tanks and I swapped the electric fan back out for the stock mechanical fan to try and sort out what is causing my issue.
    Here is what I know.
    - The coolant is bled (I'm pretty sure it is.)
    - The aux fan does not come on because I don't have freon in the system and the bolt holding one of the ac lines onto the compressor is missing (but I don't see why the car would overheat without the aux fan.)
    - The heat works and blows hot after bleeding it.
    - I have about a 5x5 inch puddle that has made its way out of the exhaust.
    Anyone have a similar problem?
    Jun 2010
    NY
    1997 328i
    Does the puddle smell sweet like coolant (smell your fresh coolant to compare). Hopefully its just condensation leaving.
    The aux fan does not rely on the AC system to work when controlling radiators temperature. To test that the fans work, unplug the sensor from the side of the rad, use a small wire to bridge the connector from center pin to one of the sides, then test to the other side (fan should come on).
    May 2018
    Portland
    95’ M3
    Puddle didn't really have a smell and it dried fairly quick. So I think it may have been condensation.
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    Under what circumstances doesit overheat? Can you give details?
    Are there any blockages? Thermostat in the correct way?
    Can you hook up a live data reader and watch the temp? Can you tell when the thermostat opens and coolant is flowing?
    May 2018
    Portland
    95’ M3
    Quote Originally Posted by Auto Parts Guy View Post
    It's a fresh swap so Ive been just running it, haven't really driven it yet.
    The thermostat is in the right way. Unfortunately, I do not have a live data reader.
    It overheats after running for an extended period of time.
    Mar 2001
    houston
    '94 325i,'08 civic
    Quote Originally Posted by brandonbeckster View Post
    does your plastic coolant tank show return to about the cold mark after running engine for extended period of time without removing cap?
    i always have to bleed multiple times to achieve that.
    Long Island, NY
    1995 M3 - 2007 X5
    The aux fan does not rely on the A/C system being full.
    When you swapped back to the mechanical fan, did you test the fan clutch?
    May 2019
    London
    E36 M50
    320i E36 1994, M50 engine
    Mine had the coolant boiling and leaking out as it boiled. Turned out to be the clutch fan. Car had 121k miles on the clock which is about right for the part.
    £30 of parts and 2 hours to swap (looked at the fan blades for 20 mins before I figured out I could palm bash the old clutch out) and test drive. No more boiling over.
    May 2018
    Portland
    95’ M3
    Turns out I had the coolant sensors on the head backwards, problem solved.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved from E36 forum to E36 M3 forum
  1. 95 S50 M3 overheating issues
    By GeorgeClues in forum 1992 - 1999 M3 (E36)
    Last Post: 11-06-2014, 07:47 PM
  2. 95 M3 overheating issue
    By flyerfan in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-07-2013, 12:09 PM
  3. 95 M3 overheating
    By M3SHO in forum 1992 - 1999 M3 (E36)
    Last Post: 11-27-2006, 04:02 AM
  4. 95 M3 exhaust issues
    By calburke in forum 1992 - 1999 M3 (E36)
    Last Post: 07-20-2006, 02:38 PM
  5. 95 M3 Overheating at 1st track event.
    By Brent951 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-12-2005, 02:13 PM
