Results 1 to 6 of 6
Thread: Double vanos on M54 engine
    Jan 2019
    Coventry
    Bmw e46
    So my vanos has been making noise for few months and I had it checked out my car mechanic who said I would need full rebuild but rebuilding my vanos can mess up my timing chains so I don't really know if I should or not any idea if is true
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Get a second opinion.
    Moved from the General BMW Discussion sub-forum.
    88M3 AW 43k miles Project FS
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    If the VANOS rebuild is just the seals and fitting anti-rattle rings, then your timing will not be altered. Easy job to do
    Should the rebuild extend to the "spline" parts (cog, wheel and cups), then yes the timing will be altered and you will need special tools to reset the timing.
    I suggest doing the seals and anti-rattle rings as a first step. Cheap and easy to do. Read up on it at http://www.beisansystems.com/
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Jun 2012
    New Mexico
    2003 328i
    The straight six VANOS is not likely to make noise. The V8's often do as the shorter cams have irregular rotational loads. They come off of one set of valves, rotate with zero resistance for 30 degrees or so and then bump into another pair of valves. The I6 has enough lobes on each cam to keep valve spring forces balanced. How did you determine that was the source of the noise?
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Yes the six cylinder BMW engines will VANOS rattle. That's why there are anti-rattle rings available for when you do a VANOS seal replacement. I recently had to replace the spline parts of the VANOS to get rid of a really bad VANOS rattle in an M52TUB engine with 112,00 miles.
    Aug 2013
    Søborg, Denmark
    2001 E46 325ti Compact
    I did the Beisan Systems seals and I’m no mechanic by any means and it was pretty easy. No timing issues whatsoever. Do it as part of changing the valve cover gasket and see if that doesn’t do the trick.
  1. 2.5 Double Vanos Engine for sale UK
    By mmoorhouse in forum Engines, Performance Parts & Software
    Last Post: 07-22-2007, 04:06 PM
  2. Double Vanos M52TU M54
    By exmaxima1 in forum Engines, Performance Parts & Software
    Last Post: 05-31-2007, 08:22 PM
  3. M54 Double Vanos, Oil pressure
    By CLN in forum 1999 - 2006 (E46)
    Last Post: 12-02-2006, 01:14 PM
  4. M54 double Vanos engine owners
    By UD///M in forum 1999 - 2006 (E46)
    Last Post: 07-01-2002, 02:36 PM
  5. S50 B30 3.0L euro engine: Single- or Double-VANOS?
    By eurospec#19 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-04-2002, 09:08 PM
