Results 1 to 10 of 10
Thread: A/C operating controls question
    May 2019
    SoCal
    M3, and M Coupe
    New M Coupe owner here.
    Should the "0" fan setting be totally off or still blowing? It seems to be the same power as "1".
    "2" and "3" and both progressively more powerful.
    Only way to turn off is to press buttons down below.
    Or, do I have a resistor or other issue? Previous owner had one of the A/C knobs worked on but I don't know the details.
    Thanks!
    May 2019
    SoCal
    M3, and M Coupe
    I found this old post. Seems strange that "0" would blow same as "1". Can anyone confirm it's operating correctly?
    The answer you seek is in the wiring diagrams. The blower motor runs at the lowest speed any time the fan switch is in position 1, or
    the fan switch is in position 0 and
    the A/C button is pushed in or
    the recirc button is pushed in.
    This is per the 2001 diagram, and I know because Di's resistor didn't make it to 200K miles.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Yes, that is correct.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    If you don't have the A/C or recirculate buttons pressed in, the fan shouldn't be running on "0". If they are, the fan will run at low speed regardless.
    May 2019
    SoCal
    M3, and M Coupe
    OK, great! Thanks guys.
    May 2019
    SoCal
    M3, and M Coupe
    NEW ADD-ON QUESTION:
    When I drive with A/C and Recirc turned Off, it usually doesn't blow any air. However, if I get on the gas, the fan definitely blows air in the cabin for a while. Is that normal??? I think it stops after a while. Not totally sure what triggers it.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Is it definitely the fan, or just air being pushed through the hevac by the air rushing over the car?
    Nov 2018
    Broad Run, VA
    1998 Z3 2.8 5sp
    Quote Originally Posted by BladeRunner919 View Post
    Mine does this. If the vents are open, air will come through even if the fan is off.
    ‘98 Z3 2.8 roadster, Montrealblau/tan 5sp, M50 manifold, AFE intake, SuperSprint catback, Bilsteins, BAVAuto sport springs, Style 42 BBS
    May 2019
    SoCal
    M3, and M Coupe
    I felt it was the fan actually blowing, but I'll have to try again to confirm, maybe it wasn't?
    Nov 2018
    Broad Run, VA
    1998 Z3 2.8 5sp
    while moving, turn the fan on to low and listen to it, then turn it off and you’ll hear that the fan motor shuts off.
  1. Climate Control Question, Please Help!
    By JL//M3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-05-2002, 03:42 PM
  2. Digital AC Climate Control Question
    By mrdoenutz in forum 1992 - 1999 M3 (E36)
    Last Post: 09-25-2001, 12:26 AM
  3. Digital AC Climate Control Question
    By mrdoenutz in forum 1991 - 1999 (E36)
    Last Post: 09-25-2001, 12:11 AM
  4. Digital AC Climate Control Question
  5. OBC Check Control question....
    By RicN in forum 1992 - 1999 M3 (E36)
    Last Post: 07-30-2001, 06:53 PM
