Results 1 to 6 of 6
Thread: Top Rear Shock Spring Pads On Bottom?
    Mar 2005
    NH
    E34 540i 6sp 1995-03-28
    Car in a shop having Koni Sport shocks put on the rear end of the 540... I supplied what I thought were all the parts for this job but the lower spring pads didn't get shipped... The shop said the existing pads were crumbled to nothing but the uppers were OK and I supplied new uppers so he said he thought they could fit the uppers in the bottom position being the same diameter...
    Just to say I asked can anyone see a problem with this? There's no conceivable way the spring could hop out or slip off the perch is there?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    I did this deliberately when overhauling my rear suspension, because the uppers are a bit softer (I also used E32 front upper spring pads for the same reason). The only problem I forsaw was water pooling around the low end of the spring, so I trimmed the rubber.
    May 2017
    Perth, Western Australia
    09/90 E34 525i (M50)
    The spring pads are only there to stop squeaks. Every other car I've had didn't have any.
    Mar 2005
    NH
    they're in and seem fine like this.... Koni sports all around now...
    May 2010
    Ontario, Canada
    1988 BMW 530i
    How does it drive with the koni shocks?
    Mar 2005
    NH
    I think its a good balance between the original touring comfort and a more responsive damper.. Hated Bilstein sports and so other than KYB you have the SACHS-BOGE original sort..
    I never drove one of these new so have no idea what the original suspension may have felt like..
    A shop owner recently told me he once met the president of Bilstein who told him he'd never run them in a BMW. so
  1. Stuck on rear shock/spring removal
    By SehrSchnell in forum 1988 - 1996 (E34)
    Last Post: 07-09-2005, 03:33 PM
  2. installing rear shocks/springs
    By enguyen7292 in forum 1996 - 2003 (E39)
    Last Post: 07-06-2005, 07:05 PM
  3. Anyone have extra set of rear upper spring pads?
    By killeen_john in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-24-2005, 11:27 AM
  4. WTB: E34 535 rear shocks & springs
    By M3 Euro LTW in forum BMW Parts Wanted
    Last Post: 01-05-2005, 09:56 AM
  5. M3 swap rear shocks/springs
    By bmwperson in forum 1991 - 1999 (E36)
    Last Post: 07-19-2004, 11:24 PM
