Results 1 to 7 of 7
Thread: Help with locating correct axles for 2003 540i manual
    May 2017
    illinois
    2003 BMW 540i MSport
    Angry Help with locating correct axles for 2003 540i manual
    Hello everyone, im in the process of returning my 3rd pair of incorrect axles. my first order was from rockauto...they sent me some garbage that wasnt even the correct length and there was no way it would bolt up to my diff. triple checked my receipt and yes it was listed as 540i/6 axles. ok so ECS tuning it is, GSP axles for 540i manual. this time the length was correct but the bolt holes were misaligned and spaced slightly too far apart. so i went to autozone and ordered the axles in store (free 2 day shipping to store at my local autozone). this time i ordered the automatic version that was for the 3.15 diffs. since i have an msport that comes with 3.15 diff instead of the 2.81 that the non-msport 540i diffs came with, i though i had it figured out. i just went to go pick up the package today and they sent me the exact same axles i ordered from ECS with the same exact dimensions and bolt pattern. i still have the axles from ECS and i compared the two side by side and no difference...it was even GSP brand in a Duralast box. am i not getting something here or am i going insane??? as always any help is appreciated and if anyone knows where i can find the correct axles please let me know.
    Missouri
    '02 540i/6
    There are two two different output flange sizes if I remember right based on VIN. Diffsonline lists two: https://diffsonline.com/bmw-e39-540-...l#.XQrU74hKiUk
    "If you have the S204A option on your vehicle, you have the 102mm option. You can also tell by the bolts that connect to the axle from the output shafts. The 94mm flanges will use M10 bolts and the 102mm flanges use M12 bolts."
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
    Missouri
    '02 540i/6
    I was going to say though. It's a common misconception, but if you have a manual, you have a 2.81 open diff. The M-Sport does have a few different things, the diff is not one of them though.
    http://bmwfans.info/parts-catalog/E3..._drive_output/
    May 2017
    illinois
    Quote Originally Posted by Iamthebull View Post
    I did a bit more research and yeah i guess youre right. now im confused as to why the axles i ordered from ecs tuning and autozone are the same...they really shouldnt be unless one of the vendors sent the wrong item right? since the axles are too large for my diff im assuming i have the 94mm flanges. im really not sure what to do now i guess i have to try ordering from autozone again..this time the manual option -_-. would you maybe know if the touring axles are any different than the sedan?
    San Jose, CA
    1997 BMW 540i 6 speed
    Why not try ordering by BMW part number? www.realoem.com
    May 2017
    illinois
    Quote Originally Posted by edjack View Post
    I tried looking up by part number all i got was remanufactured oem axles that were $300-500 per side. Not really in the mood to pay that much
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    What’s bad about your current ones? Repack the joints, and put new boots on if they are otherwise ok
  1. E39 2003 540i Manual $15,490
    By lurch09 in forum 5 series & 6 series
    Last Post: 08-30-2012, 08:34 AM
  2. Help - wheel well repair/replacement (2003 540i sport)
    By jamesdc4 in forum 1996 - 2003 (E39)
    Last Post: 01-15-2009, 01:48 PM
  3. HELP locating ICV on my 2000 540i V8
    By erickdav in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-29-2008, 04:15 PM
  4. Need help with pricing on 2003 540i M-Sport??
    By E36Shikara in forum 1996 - 2003 (E39)
    Last Post: 05-09-2007, 02:24 PM
  5. Making offer on a 2003 540i sport - need help
    By mRoadsterGator in forum 1996 - 2003 (E39)
    Last Post: 12-11-2006, 10:31 AM
