Results 1 to 6 of 6
Thread: E36 driveshaft help
    Aug 2009
    CA
    E36
    E36 driveshaft help
    On a 96 and up 328i is the rear part of the driveshaft the same manual to auto? and just the front half different?
    what im asking is could I use a auto rear and manual front and have a driveshaft that would work in a manual car?
    Feb 2016
    Rogers AR
    1995 BMW M3
    the fronts are different, but I believe the rears are all the same. I have heard but have never verified that each section is balanced individually, so in theory you could mix and match as you have stated.
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    Of all the e36 driveshafts I've dealt with, the rears have all been the same. Just pay attention to the diff bolt pattern.
    And on the front, dont forget there are 2 bolt patterns there as well (small & large).
    Aug 2009
    CA
    E36
    Quote Originally Posted by Auto Parts Guy View Post
    Ok I will keep that in mind, and I wonder if they are really balanced? I guess I can have it balanced at a driveshaft shop.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There is usually a white dot on each half at the joint. Line up the dots. If mixing and matching, line up the dots if they are still visible. If they are not present then get it balanced. Beware most 20+ year old rear joints are worn out and most shops won’t replace them because they are staked and not easily removeable.
    NW suburban Chicago
    hiss by my window
    It's my understanding that the marks are to keep the joints in phase, not for balancing.
    Out of phase U joints will cause a vibration which could be misdiagnosed as out of balance.
    I have a complete manual driveshaft if you are looking for one.
  1. E36 driveshaft help needed.
    By guymandude in forum 1991 - 1999 (E36)
    Last Post: 10-24-2016, 09:36 PM
  2. E36 driveshaft help needed.
    By guymandude in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-18-2016, 12:15 PM
  3. E36 WTB: e36 Driveshaft (4 bolt rear)
    By pandaboo911 in forum BMW Parts Wanted
    Last Post: 02-14-2013, 08:30 PM
  4. E36 Anyone want to make some cash? E36 Clutch help in Connecticut needed
    By turbotime in forum 3 series & Z Series
    Last Post: 06-01-2011, 11:43 PM
  5. E36 E36 Driveshafts (manual, auto, m3, non-m, 4 and 6 bolt)
    By SQ Bimmer in forum Drivetrain & Transmission Parts
    Last Post: 01-07-2010, 09:15 PM
