I have a '86 325es with an m50. I need help figuring out what my options are for a 7k cluster. I currently have a 5k VDO cluster without a coding plug. Is there any particular cluster that I need to avoid (like form a 4 cylinder), or will any cluster from any car will work. Thanks for the info.
since you have an m50, I would go with one from a 325i because its already got the higher tach and is a 6 cylinder. you could probably just as easily use your current cluster though, since its a 6 cylinder one also
No e30s again.
