Results 1 to 10 of 10
Thread: E39 Exhaust Cutout
    Dec 2018
    Chicago, IL
    2003 E39 525i
    E39 Exhaust Cutout
    I want to buy a cutout for my 2003 525i, and I just wanted to double check that I had the outer diameter right before buying one. I measured the outer diameter of my exhaust at 2.5" inches. Please let me know if that's right. And does anyone know where near the battery I can get key on only constant power for it?
    Ryan Kasko
    Cars:
    -2003 E39 525i with only 60k on the odometer!
    Bought October, 2018
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    I have a QTP electric cutout on my 540.
    Depending on where you put it the pipe could have a double wall.
    I cut a hole in the dead leg of the Y resonator then welded on a short section of pipe and a flange for the cutout.
    Yes I know my welds look like crap, that was the second time I used a TIG welder.
    The intention was to run it back to the bumper for a dual exhaust setup that I haven't done yet.
    Dec 2018
    Chicago, IL
    2003 E39 525i
    The welds aren't horrible and I was planning on putting mine in a similar spot. What size cutout did you need to order?
    Ryan Kasko
    Cars:
    JimLev's Avatar
    Sundance Mesa, NM
    Those welds are crap, at least they don't leak.
    I used a 2 1/4" QTP, had to keep it on the small side, there isn't a lot of clearance under the car.
    These are good TIG welds.
    Last edited by JimLev; 06-20-2019 at 02:22 PM. Reason: Corrected the size, 2 1/4" not 2 1/8"
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    Jim that's one nice placement for that cutout, as the other branch that normally acts as the tailpipe would sort of take up the function of a resonator if you have a muffler in place. How does it feel with that cutout? Also, the valve you're using looks extra nice, as everthing in your car. Where did you get it?
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
    May 2018
    Austin, TX
    00 M5 | 03 540i | 94 NSX
    JimLev what kind of sound do you get with the cutout at that location? I've been thinking of doing an electric cutout too.
    JimLev's Avatar
    Sundance Mesa, NM
    Don't expect and seat of the pants gains, I did this as the beginning of a dual exhaust setup but as usual something else got in the way (LS3 '33 Ford build).
    The left side has a nice small Vibrant dual tip muffler. I wasn't going to put a muffler on the right side, just some matching dual tips that I had that are now on the '33.
    I corrected the post above, I used a 2 1/4" QTP, this one.
    https://www.summitracing.com/parts/q...c225/overview/
    I like that I can control how much it opens/closes to control the amount of deep tone from it at the low/mid RPM's.
    With it full open at 5-6500 RPM it sounds more like a 12 cyl European car.
    Jan 2012
    NYC
    2003 530i, 2005 X5 3.0
    Just curious does all the exhaust go through the cutout once full open? Or does some of it still go through the muffler?
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by MotorMouth93 View Post
    It's a pretty deep mellow tone unless you wind it out to redline.
    I'll see if I can find a short clip of it.
    25% open clip
    https://1drv.ms/u/s!ApkTIzHhyMd5mBH2EymidsHS_85c
    When it's 100% open it's louder and has a slight rasp only when cold if you goose it, it goes away after the 1st mile.
    I think it's the internal perforated section in the resonator that you can see in the post 2 pic above.
    The next time I have it apart I'll put a tack weld on it and the internal pipe so it won't vibrate.
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by bossman1 View Post
    It's about 50/50 when wide open.
    You can see straight thru my Vibrant muffler. Much smaller than the OE twin scuba tanks and 37 lbs less.
    Inlet
    Outlet
  1. E39 E39 Carbon Fiber Diffuser Dual Exhaust Cutout
    By Narvin in forum Exterior Lighting & Body Parts
    Last Post: 08-22-2012, 09:22 AM
  2. E39 E46 Remus DTM exhaust - $200 + Stock muffler or E39 Exhaust
    By DevIouS One in forum Engines, Performance Parts & Software
    Last Post: 10-26-2009, 03:28 PM
  3. E39 FS: REMUS e39 Exhaust
    By Ellicit in forum Engines, Performance Parts & Software
    Last Post: 03-09-2009, 03:28 PM
  4. E39 FS 5 series e39 exhaust system
    By Arctic///M3 in forum Whole Parts Cars
    Last Post: 04-18-2008, 01:33 PM
