Results 1 to 4 of 4
Thread: Will my car run with all these codes?
    Jun 2019
    Petaluma CA
    2001 BMW 330ci
    Just bought a 2000 325ci. Another victim of the dead auto trans. Last owner said it was running when parked,but sat for about half a year, so i just flushed all the fuel. I threw a new battery in there, checked all the fluids and tried to start it. It definitely has fuel as i can smell it when its cranking, and i know it has spark because occasionally it will try to kick over. Also definitely has compression, so i checked the DCTs. 14 codes; P0720, p1751, p1749, p0715, p0727, p0731, p0732, p0733, p0734, p0735, p1747, p1748, p0705, and p0763. I did a real quick search on all these, and so far they all seem to be trans related, but would any of these keep the car from running? Also, i am planning on doing a 5 speed swap, but i dont have a harness, so is there at least a way i can get the car running without any of the trans harness plugged in?
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    - Air. Blocked air cleaner. Vacuum leaks, broken rubber boots, especially the small one going to the idle control valve.
    - Fuel. 50 PSI pressure at the fuel rail. Clean working injectors.
    - Compression. For you to test.
    - Spark. Check a removed plug to see the spark.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Jun 2012
    New Mexico
    2003 328i
    I'm not googling 14 codes. If you want to do so and post the descriptions of them we can go from there.
    Jun 2019
    Petaluma CA
    2001 BMW 330ci
    Quote Originally Posted by Muzz258 View Post
    Thank you. A few of the pcv lines were split so i temporarily taped them up just to see if it would start. Although i had flushed the fuel, i reflushed it, and replaced the spark plugs. Looked like all the plugs were fouled and had an excessive gap over .040. I was able to start it, and although it sputtered and stalled a few times, i was able to eventually get it to idle ok. Thanks for the suggestions!
  1. Car running rough--misfire fault codes
    By cngizbleevng in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-20-2018, 10:28 PM
  2. Car running rich/No misfires Codes P0173 and P1270
    By rahee006 in forum 1995 - 2001 (E38)
    Last Post: 11-11-2014, 04:33 PM
  3. Car runs FINE..but throws code P1340?
    By SHOWCASE in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-24-2009, 03:02 PM
  4. Check engine code 1215....car runs fine. What gives?
    By b70002 in forum 1991 - 1999 (E36)
    Last Post: 04-20-2007, 09:33 PM
  5. Car running like poop, a buch of codes, help?
    By dls98E36 in forum 1991 - 1999 (E36)
    Last Post: 02-01-2007, 06:12 AM
