Just bought a 2000 325ci. Another victim of the dead auto trans. Last owner said it was running when parked,but sat for about half a year, so i just flushed all the fuel. I threw a new battery in there, checked all the fluids and tried to start it. It definitely has fuel as i can smell it when its cranking, and i know it has spark because occasionally it will try to kick over. Also definitely has compression, so i checked the DCTs. 14 codes; P0720, p1751, p1749, p0715, p0727, p0731, p0732, p0733, p0734, p0735, p1747, p1748, p0705, and p0763. I did a real quick search on all these, and so far they all seem to be trans related, but would any of these keep the car from running? Also, i am planning on doing a 5 speed swap, but i dont have a harness, so is there at least a way i can get the car running without any of the trans harness plugged in?
- Air. Blocked air cleaner. Vacuum leaks, broken rubber boots, especially the small one going to the idle control valve.
- Fuel. 50 PSI pressure at the fuel rail. Clean working injectors.
- Compression. For you to test.
- Spark. Check a removed plug to see the spark.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
I'm not googling 14 codes. If you want to do so and post the descriptions of them we can go from there.
Thank you. A few of the pcv lines were split so i temporarily taped them up just to see if it would start. Although i had flushed the fuel, i reflushed it, and replaced the spark plugs. Looked like all the plugs were fouled and had an excessive gap over .040. I was able to start it, and although it sputtered and stalled a few times, i was able to eventually get it to idle ok. Thanks for the suggestions!
