Results 1 to 9 of 9
Thread: Should a car noob attempt to do a cooling system overhaul themselves?
    Jun 2019
    USA
    2004 BMW 325xi
    The extent of my mechanic work has been replacing a civic radiator and thermostat, and oil/oil filter changes. Just bought a '04 e46 as my third car, and my last two were hondas. Is it doable to overhaul the entire cooling system as a beginner with just youtube and a weekend of time? Or is this just a stupid idea? I have the money to buy the parts but not enough to pay for a mechanic's labor.
    Or would I be better off just starting off by replacing the fan clutch and/or radiator fan for now? I suspect one of those things is the culprit based on what I've read on this forum, since the car doesn't leak coolant or anything and it has a brand new water pump. Also, both heat and A/C work so I don't think it's the thermostat either. Plus it cools off while driving. Only time the gauge starts creeping up is when I'm idling for too long at a drive through or something (like 10 minutes). As soon as I drive off it cools down immediately.
    edit: car is at 80k miles and someone recommended i overhaul the entire system before 100k.
    Mar 2011
    PNW
    LS E46
    This is actually the easiest cooling system to work on. There are no gaskets and no hose clamps. The water pump has an o-ring to seal and is bolted in place with 4 small bolts. The cooling hoses also use o-rings to seal and are just clipped into place. Working on a BMW reminds me of a “my first tool set” kit for a child.
    Mar 2019
    ATLANTA GA
    456 X3s
    It's all doable...if you have time,patience and strong comprehension skills and finally a second car.
    Sent from my SM-G531H using Tapatalk
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Buy yourself a Bentley manual. It’ll save you a ton of time and frustration. Be advised that installing aftermarket cooling system parts is strictly verboten.
    Jan 2016
    Ca
    2001 525it
    The front of the coolant system is the most stressed part. The main thing I would look for is the color of the expansion tank and hose connectors, black originall, brown when old. To do a complete cooling system would also involve removing the intake manifold and replacing the plastic water pipes. Replacing the water pipes was the first thing I did on my car along with cycling valves and vacuum hoses. Leave the fan clutch on, it works fine.
    Aug 2013
    Søborg, Denmark
    2001 E46 325ti Compact
    I did it and I’ve never worked on cars before. It’s a pretty straightforward job. I found some good DIY’s on YouTube and got cracking.
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    May 2009
    Greenville, SC USA
    Mar 2011
    PNW
    LS E46
    Sprechen sie englisch?
  1. Cooling System Overhaul - Loving My Car Again
    By E46 Ci in forum 1999 - 2006 (E46)
    Last Post: 02-22-2012, 12:21 PM
  2. Can an unlevel car cause air to get into cooling system?
    By pacogrande in forum 1988 - 1996 (E34)
    Last Post: 09-12-2007, 01:23 PM
  3. Want to Dyno the car...noob questions.
    By Ruffian in forum 1983 - 1991 (E30)
    Last Post: 07-24-2007, 07:01 PM
