Results 1 to 8 of 8
Thread: e34 535i down on power
    Apr 2019
    canby, OR
    1990 bmw 535i
    hello i have a 1989 bmw 535i and it has an eradic idle at about 1100rpm but when in drive goes down to about 450rpm it smokes a little bit of white smoke/steam and is down on power wont even spin the tires it also throws a 1222 code with the stomp test
    edit: found that it had skipped 3 timing teeth!!! and she still ran! previous owner was an idiot, told me he had changed the head gasket but i don't think he did even that right, my oil is starting to get milky maybe its because it was off 3 teeth? any help is appreciated
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    Sounds like you have it figured out, blown head gasket and improper timing.
    O o
    ____________________________ ______________
    | BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
    \_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Apr 2019
    canby, OR
    1990 bmw 535i
    Ok thank you i just wanted a second opinion
    It runs a lot smoother now but still down on power
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    Skipping 3 teeth.. and it still ran? That's a data point.
    If you want a look at engine function I'd suggest a compression test, or better, a leak-down test. But if you are getting milky oil most would think it's a bad head gasket and you'll have the opportunity to examine piston tops and valves then.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Apr 2019
    canby, OR
    1990 bmw 535i
    It was either 2 or 3 teeth i can't remember. But it ran and and ticked now it doesn't (besides rocker arms)
    Apr 2019
    canby, OR
    1990 bmw 535i
    it also says trans program
    Apr 2017
    California
    I hope you didn’t pay much for this car...
    O o
    Apr 2019
    canby, OR
    1990 bmw 535i
    nope, $300.
  1. E34 535i loss of power help!
    By misiuu92 in forum 1988 - 1996 (E34)
    Last Post: 05-25-2015, 04:23 PM
  2. e34 535i Power windows don't work
    By Funkalicious in forum 1988 - 1996 (E34)
    Last Post: 08-15-2014, 08:58 PM
  3. e34 535i Power windows don't work
    Last Post: 08-15-2014, 12:03 PM
  4. e34 535i sport auto power
    By carnutter in forum 1988 - 1996 (E34)
    Last Post: 02-15-2013, 03:44 PM
  5. My M30B35 Powered E34 535i - Flowmaster Exhaust (Video)
    By moonsspoon in forum BMW Rides & Events
    Last Post: 06-04-2008, 07:35 PM
