Results 1 to 5 of 5
Thread: H/k system with no sound
    Apr 2017
    Utah
    E32 bmw and 95eg civic
    I have the h/k setup in my m3 every thing works but I get no sound at all is the amp bad ? Also does any one know why my climate control and obc turn on and off when they want
    Oct 2003
    Seattle
    99 M3
    Most likely your amp is dead.
    My trunk seal leaked and moisture found a path to the top of the amp and into the connector.
    I found a method of covering the replacement amp and wiring with a heavy clear produce plastic bag.
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by Dominick936 View Post
    I have the h/k setup in my m3 everything works but I get no sound at all is the amp bad?
    In the trunk, remove the drivers rear tail light cover, then pull the trunk liner towards the center to access the amplifier. Do you have a test light or volt meter?
    1, the large red/white wire should have constant 12 volts. 2, the small white wire (from radio) should have 12 volts with the radio on. If 2 does not, pull your radio and check to see if it has 12 volts there. If 2 does have 12 volts, most likely amp.
    This happens a lot, a simple fix just do a search.
    [IMG][/IMG]
    Oct 2003
    Seattle
    99 M3
    For the OBC - This could be related to the trunk wire loom failure that is also well documented. BMW has a factory repair loom.
    Jul 2018
    St. Paul, MN
    98 & 99 M3, '06 E60M5S3
    If your amp is dead and you're wanting to replace it, I have the amp pulled from my '98 M3 when I upgraded the audio in there. Feel free to message me here if interested.
  1. Sos system malfunction no sound
    By Dskee1223 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-13-2017, 12:23 PM
  2. Cooling System again... hissing sound.
    By bmcknight13 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-09-2014, 08:17 PM
  3. z3 HK system, New headunit -> sound quiet...
    By csl223 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-30-2012, 11:08 PM
  4. Changing stock system with HK Sound
    By Jademonkey in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-02-2007, 06:33 PM
  5. What is the best Exhaust system . Pics and Sound if possible
    By Blaze One in forum BMW Rides & Events
    Last Post: 05-25-2004, 11:55 AM
