Results 1 to 4 of 4
Thread: High Pitch whistle, No carb cleaner leaks ANYWHERE.
    Sep 2018
    South Dakota
    2001 740iL
    This vacuum is causing misfire on 4 cylinders and it is loud under acceleration. Can't find the source with the hood up, sprayed every gasket and hose I could find. No smoke machines available near me.
    With a rubber hose (fake stethoscope) behind the Intake manifold (bottom of CCV) I hear very slight wind, I cant spray underneath and upwards there but everywhere else around the housing seems sealed.
    Is this normal? Or should I go ahead and replace the CCV. I've read it can be the source of many problems when clogged or leaky. Any tricks for diagnosing that doesnt require a BMW manometer I can't seem to find anywhere online?
    Houston
    2001 740il
    Quote Originally Posted by Indigo46n2 View Post
    Pull the manifold and change all gaskets including front and back.
    Sent from my LG-G710 using Tapatalk
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by Zedbimmer View Post
    High pitch whistle is probably CCV, the problem with that that only genuine BMW works long term. I agree that I'd change all the manifold gaskets as well, not a big job and worth it.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Pull your dipstick to see if you hear gurgling and if there is a good deal of suction when you put your finger over the hole.
  1. High Pitched Whistle When I hit the gas
    By ISHIFT5 in forum 1999 - 2006 (E46)
    Last Post: 11-14-2007, 04:17 PM
  2. Intermittent high-pitched whistling (like a tea kettle or loud ringing in ears)
    By nmark in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-30-2007, 01:40 PM
  3. high pitched whistle
    By GreenBMW325is in forum 1991 - 1999 (E36)
    Last Post: 05-22-2005, 12:33 PM
  4. High pitched whistling 328's!!
    By M52 POWER! in forum 1991 - 1999 (E36)
    Last Post: 04-25-2005, 08:31 PM
  5. conforti CAI - high pitched whistle problem
    By joey v in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-11-2004, 07:40 PM
