Hi guys I know the pipe work won't fit or anything, but has one got a 318 I radiator on a 325i as I'm doing an engine swap and wonder if it will run with the 318 radiator so I don't need the seperate tank thanks
if you mean "will the radiator bolt in?" the answer is yes.
The 318i radiator won't have the cooling capacity needed for a 325i.
"Howdy, Folks!"
the post right above your question says no.
the m10 318 radiator is a fair amount smaller then the m20 radiator that the 325 use
No e30s again.
