Results 1 to 11 of 11
Thread: Some Thoughts for Those Who Use the CES Cutring Gasket w/ Spacer.
    May 2015
    96 Hellrot 328is Turbo
    I just pulled the head off of my M52, because it was getting some coolant in cylinder 4. The head was cracked, totally my fault for overheating the engine. Anyway, while I was coming apart, I noticed that the two small head bolts that go into the timing cover were *almost* hand loose. They were not tight at all, which I now figure is why I had an oil leak from my timing cover, because it is not common for those to leak.
    CES recommends pulling the valvecover and retorquing the head after heat cycling the engine. When I did this I did not retighten those bolts in the front, probably because I figured it wasn't going to be an issue. But it was, and I should have. The copper spacer crushed down quite a bit over time, especially where the cut rings were, but I imagine the whole thing did due to being a soft metal heating and cooling under the head. Or perhaps it was just the first few heat cycles. Either way, it was enough that those bolts were loose as hell and causing an oil leak.
    The other thing I noticed was just how good the seal of the gasket was, and how good the condition of it is now that it is back out. I ran it for 25k, and the actual gasket looks brand new. I honestly think I could throw it back together and it would seal. It is that good. Amazing gasket, and I can't say that enough. I will continue to use them.
    The last thought I had is that if the copper spacer is crushing down quite a bit, it is raising the compression. Not enough to make a major difference I don't think, but still, that is a thing that is happening.
    Oct 2005
    Canberra, Australia
    93' Turbo 325i Coupe
    Good to know, I just threw that combo in my M50, yet to fire it up for the first time but I'll certainly re-torque those timing cover bolts now too once I pull the valve cover.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Ive actually never used those timing cover bolts, just some silicone on the front.
    Retorque is important.
    Montreal, QC Canada
    328is GT35R
    Is there any point in re-torquing after a few thousand miles or is it too late? I'm afraid I did not re-torque.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Im pribably 2-3k in on my most recent build, cutring with arp's every nut took half a turn, they moved with 65ftlbs
    FL
    are slow.
    Quote Originally Posted by daze450 View Post
    Would probably be a good idea to check them. Copper compresses with pressure, heat and time. It's not too late.
    -Dr. Seuss
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by Hova View Post
    No copper spacer on mine and the retorque took half a turn.
    Montreal, QC Canada
    328is GT35R
    Thanks guys! ill check em out.
    Geigertown, PA
    95 M blk/blk
    Do you need a special socket to get to the head nuts with the cams in?
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Some sockets are a tight fit.
    Jan 2021
    Ny
    94e36, 00e39 532it turbo
    this one has a thin enough wall it just fits.
    They make a 12 point impact that looks similar. (but I have no experience with the black impact version. )
  1. FS: CES Cutring Gasket 84-85mm Bore Size
    By kairaspo in forum Forced & Chemical Induction Parts
    Last Post: 01-28-2016, 05:03 PM
  2. CES cutring gasket/spacer s50/s52 - No Longer Available
    By graphite9 in forum Forced & Chemical Induction Parts
    Last Post: 03-24-2015, 05:22 PM
  3. to those who use oil extractors
    By kosta in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-25-2003, 01:56 PM
  4. Found this...Thought it would be useful to you guys.
    By bmwpower in forum 1987 - 1991 M3 (E30)
    Last Post: 10-02-2002, 12:41 AM
  5. Question for those that use claybars....
    By SteveB in forum 1992 - 1999 M3 (E36)
    Last Post: 04-12-2001, 03:52 AM
