Results 1 to 4 of 4
Thread: 97 328i runs rough until 3000 rpm.
    Jun 2019
    Illinois, USA
    1997 BMW 328i
    I've purchased this car with a slew of problems some easy fixes but I've come to an impasse and need some recommendations on what to check next. The car starts and idles fairly well which it wouldn't before I fixed the vacuum leak it had on the valve cover. It's just a little rough, and you can hear it in the exhaust kind of like a sputtering, until it revs past 3K rpm. I'm using one of those fix'd sensors I borrowed from someone because the car isn't plated. I've got a CEL with codes P0150 which is bank 2 sensor 1 O2(correct me if wrong might be bank 1) and P0101 which is generic code for maf I believe.
    I don't want to just buy an O2 sensor and want to hear if anyone has had similar issues and what fixed it. Thanks in advance for your help.
    Dec 2013
    Chicagoland area
    EXOTICS
    Swap sensors,
    Observe if codes follow.
    Jun 2010
    NY
    1997 328i
    Jun 2019
    Illinois, USA
    1997 BMW 328i
    Quote Originally Posted by MIKYZZ4 View Post
    Swap sensors,
    I did that while running which I should probably switch them before and got p0155 and p0135 for circuit problems going to try this while off and see if I get p0130
  1. Rough Idle, rough running under 2500-3000 rpms
    By UptownLove in forum 1988 - 1996 (E34)
    Last Post: 01-24-2012, 12:58 AM
  2. 328i runs rough after it Warms Up HELP
    By malibu73 in forum 1991 - 1999 (E36)
    Last Post: 08-17-2007, 07:39 AM
  3. 1991 328i running rough
    By sboliek in forum 1983 - 1991 (E30)
    Last Post: 05-29-2007, 12:26 AM
  4. Runs rough at low rpms
    By seeocoee in forum 1991 - 1999 (E36)
    Last Post: 11-11-2006, 03:03 AM
  5. 97 540 runs rough when cold..why?
    By tacurt in forum 1996 - 2003 (E39)
    Last Post: 09-02-2006, 10:20 PM
