Results 1 to 9 of 9
Thread: Just finished some pretty major maintenance/restoration
    Feb 2012
    Maryland
    1990 750iL, 2005 X5 3.0i
    I just finished a bunch of stuff on my '90 750iL. The blower motor went up and the heater core had a small leak as evidenced by some minor morning fog at the bottom of the windshield. It hadn't had a good going through for about 70,000 miles, the valve covers were very rusty, it still had cosmoline all over the intakes, and since the blower motor is even easier to do with the intakes off...I decided to go for it. I sandblasted and painted the intakes and valve covers, bench cleaned the injectors and replaced the O rings and pintle caps, replace the plugs, plug wires, caps, and rotors, replaced all the fuel hoses and vacuum hoses, cleaned all the electrical connections and replaced a couple of broken connectors, replaced both belts and tensioners, replaced all the rubber mounts (oil filter housing, MAFs, intake supports, etc), replaced the motor mounts (one was toast and one cracked) and trans mounts (one cracked there too), cleaned the MAFs, replaced the throttle bodies with reman ones I got with the car, replaced all the intake/MAF boots, replace the trans cooler lines (one had a small leak), cleaned and sealed the intake gaskets (which were in great shape, thank you God), replaced the upper and lower control arms (one upper was starting to vibrate during braking) and the rear dog bones, replaced the hood and trunk struts, inspected the LAD system and shocks (all good), replaced the heater core and blower motor and checked out the sword, and took care of anything else that looked suspect. I think that's it.
    Feb 2012
    Maryland
    I'm not sure why it insists on loading the first and last pics sideways.
    Sep 2015
    San Diego, California
    94 740i, 03 525iT, 86 VW
    Quote Originally Posted by 2shelbys View Post
    Holy crap that is awesome. I just turned my head sideways... totally worth it! Pic #4 is gnarly by the way... How long did this all take you? My 740i could use some of that kind of TLC for sure.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Nice and clean engine bay again. Painting the valve covers on the M70 makes a big difference, we did my ones in 2012, here pics before and after http://e32b12.blogspot.com/2012/08/r...y-4-final.html
    Dec 2005
    Baltimore, MD
    81 Scirocco-92 750il
    I did mine a while back and it's still rolling strong because of it. I did go a little nuts with the polishing though...lol
    http://www.mk1motorsports.com/the-e32-750il.html
    Where in MD are you? We need to meet up. I have a whole parts car and then some if you need some stuff....I'm in California, MD about an hour south of the DC beltway.
    Feb 2012
    Maryland
    Thanks. I did it over the course of a couple of weeks on my days off. Spent some time waiting for stuff to be delivered and waiting for nice enough days to sandblast and paint outside.
    Feb 2012
    Maryland
    Yes, painting them definitely makes a big difference. Mine were really rusty as you can see in that one picture. It looks so much better now. Now I need to do some work on the body. Getting out some dents, fixing some scratches, and repainting the sunroof because the clear all came off of it. And I’ll be installing your chipset.
    Looks awesome. I’m in White Marsh. Opposite side of Baltimore.
    Dec 2005
    Baltimore, MD
    I'm in downtown Baltimore frequently. Sometimes with my 7. Stay in touch....
    Jul 2019
    Ropesville, Texas, USA
    1984 BMW 318i; 1978 F150
    That is awesome
  1. Replies: 4
    Last Post: 02-02-2003, 08:40 PM
  2. just finished heat shield!!
    By PECivil in forum 1991 - 1999 (E36)
    Last Post: 04-03-2002, 09:25 AM
  3. just finished install my brake pads/rotors
    By Saul in forum 1992 - 1999 M3 (E36)
    Last Post: 10-10-2001, 09:41 PM
  4. Just finished some "homemade" mods!!
    By VOLSBimmer in forum 1991 - 1999 (E36)
    Last Post: 08-23-2001, 04:03 PM
