Results 1 to 8 of 8
Thread: Where are the chassis grounding locations?
    Mar 2019
    Texas
    Mazda Miata
    I have a grounding issue. Occasionally when I turn on my blinker, the entire instrument cluster loses power and the needles fall back to zero, only to catch themselves and reset. It's also causing a check engine light for the O2 sensors losing momentary power.
    I have replaced the negative battery terminal and it has helped tremendously. It's gone from almost every time I use the blinker to maybe once or twice per car ride.
    I want to check the other grounding locations to make sure they are tight and getting a good connection. I have googled and looked all over this forum, but haven't been able to find solid info about where they are. I've found wiring diagrams, but not the actual grounding locations on the chassis.
    Could anyone shed some light on this?
    Pittsburgh, PA
    94 325ic, 08 X3 3.0si
    I believe it's on the passenger side near the bottom of the engine block. You can see it when you look down through the engine bay. It's a braided chord and It'll go from right to left.
    Mar 2019
    Texas
    Mazda Miata
    Quote Originally Posted by WELSCH325i View Post
    Thank you for the response. Is that all of the grounding locations?
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    As Welsh was saying, the engine grounding cable is on the passenger side engine mount. It runs under the mount and is attached to the bottom side of the passenger frame horn with a 13mm nut.
    There are plenty of other grounds located throughout the car.
    Mar 2019
    Texas
    Mazda Miata
    Quote Originally Posted by 66 6 View Post
    Thank you for the response. Would you happen to have any idea where those other grounds could be located so I could check them?
    Mar 2019
    Texas
    Mazda Miata
    Would anyone know where I could find more info on this?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Here: (this address is for my M roadster, but you can then find the one for your car): http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    Mar 2019
    Texas
    Mazda Miata
    Thank you. Great link, plus the subdirectories are particularly useful.
  1. e34 ground locations
    By dourwolf in forum 1988 - 1996 (E34)
    Last Post: 03-23-2010, 07:31 AM
  2. Location of Engine/Chassis ground?
    By turnerNCM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-23-2007, 06:48 PM
  3. a good ground location?
    By luckytopher in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-09-2005, 09:24 AM
  4. Recommend Ground Location for HU?
    By C///M3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-27-2004, 11:32 PM
  5. What's a good ground location near the A-pillar?
    By archyx in forum 1992 - 1999 M3 (E36)
    Last Post: 06-18-2004, 07:01 PM
