Results 1 to 11 of 11
Thread: car fm radio antenna booster
    Feb 2014
    allentown
    99 Z3MC/00' 2.8 roady
    I never had the factory radio in my Coupe, PO had already removed it. When I purchased the car I had an alpine head unit installed and still had poor fm reception. Has anyone had any luck with a fm radio antenna booster.
    Kent, Ohio
    1998 M Roadster
    You mean radio, as in broadcast through the airwaves? Do they still do that?
    Feb 2014
    allentown
    Sep 2017
    South Central PA
    '00 Z3 2.3 Roadster
    I ran one similar to above in my GTI when I replaced the stock antenna mast with a shorter 'bee stinger' mast. It helped, somewhat. Still didn't seem as good as the stock VW.
    Z's have the OEM amplified base, same thing right? It certainly cant hurt to try.
    Feb 2014
    allentown
    Ok.. I will check the amplified base out for any corrosion first and see if all connections are ok.
    Jun 2019
    plano TX
    2000 Z3 Coupe
    I just got a 2000 coupe with factory radio unit. The signal is terrible even though the unit is in perfect condition. But I am going to replace it with a sony unit so that I can just listen to my own music via bluetooth going forward..
    Feb 2014
    allentown
    My Alpine has a USB port. So I just plug in thumb drive that has about 3k songs on it, but sometimes I like listening to a station.
    Kent, Ohio
    1998 M Roadster
    I mean mine connects by bluetooth to my phone and I just stream whatever I want to listen to--podcasts, Apple Music, Pandora, NPR--you name it, it's on the internet. I haven't tuned in to an actual radio station in years.
    Sep 2017
    Northeast
    2001 M Roadster
    I tried one of these. Had good reviews on amazon. It is still installed. Does absolutely nothing for improving reception with stubby antenna.
    Feb 2014
    allentown
    I pulled the antenna base out of the car and it looked clean, no corrosion. Next up I tore the Alpine HU out of the car to check the antenna cable. Now the PO had the car broken into and the thieves cut a bunch of wires stealing the radio and amp including cutting the antenna cable. I had a shop install the Alpine HU and Alpine amp. They tried fixing the cut antenna cable, but I guess not very successful. So I bought a 44" extension cable and cut what I needed and soldered them both together. I now have Radio reception again.20190622_192234.jpg
    Jul 2010
    Ozark bumps
    00 M Roadster 17 Cayman
    “I just got a 2000 coupe with factory radio unit. The signal is terrible even though the unit is in perfect condition. But I am going to replace it with a sony unit so that I can just listen to my own music via bluetooth going forward..”
    l recommend looking at the Grom unit. It adds Bluetooth, usb capability to the OEM headunit (which is not a bad head unit; albeit dated functionally) and maintains OEM look.
  1. fm radio antenna location.
    By Johnny Kim in forum 1996 - 2003 (E39)
    Last Post: 06-01-2019, 07:03 PM
  2. Jap Spec Car Radio/Antenna Amp/Keyless FOB Questions
    By atcguy2008 in forum 1999 - 2006 (E46)
    Last Post: 09-27-2015, 04:26 PM
  3. FM radio help? is it the phone antenna or both?
    By pwhitt in forum 1995 - 2001 (E38)
    Last Post: 01-22-2012, 10:22 PM
  4. External Radio Antenna Booster?
    By P11 in forum 1996 - 2003 (E39)
    Last Post: 12-08-2009, 04:34 PM
  5. Stock FM Radio Problems - Is my antenna amp bad?
    By rasher in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-07-2006, 11:26 AM
