Results 1 to 6 of 6
Thread: Identifying broken wire on Bi-Xenon headlamp unit.
    Apr 2016
    Sammamish, WA
    2006 E46 330cic ZHP
    Hi,
    I have a 2006 330cic ZHP. The previous owner disconnected the headlamp washers and I was poking around looking to re-enable them. I stumbled on a wire that was broken going into my drivers-side headlamp unit.
    I'm trying to understand what this wire is before I reconnect it. Headlamps appear to work correctly, high beam, low beam, daylight running, leveling and steering. I've attached a photo of the wire below, as well as a screen cap from a video that shows the actual connector.
    Any ideas here?
    Thanks!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What color/s is the wire?
    Michigan
    2005 325Xi
    The headlight washers work by the washer pump pressurizing the system. There are 2 washer pumps in the washer jug, one for the windshield, and one for the headlights. The washers themselves are purely mechanical, unless they're heated. But reconnecting a wire will not cause them to operate, unless that wire is for one of the washer pumps in the washer jug.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Apr 2016
    Sammamish, WA
    2006 E46 330cic ZHP
    Quote Originally Posted by MarcoZandrini View Post
    The wire is yellow.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    I *think* this may be adaptive headlight wire since all other functions work fine and this is a very late e46.
    Apr 2016
    Sammamish, WA
    2006 E46 330cic ZHP
    Thanks for the help here. I repaired it this evening, it may have been the headlamp leveling function. I'll be looking deeper into that washer issue this weekend!
  1. Bi-xenon headlamp problems (ZHP)
    By psychocandy in forum 1999 - 2006 (E46)
    Last Post: 04-21-2010, 11:14 PM
  2. E46 M3 HID OE Bi-Xenon headlamps
    By bahnfire318is in forum Exterior Lighting & Body Parts
    Last Post: 01-15-2010, 04:02 PM
  3. E46 M3 HID Bi-Xenon headlamps FS.
    By DallasCLK in forum Exterior Lighting & Body Parts
    Last Post: 03-11-2009, 10:14 PM
  4. bi-xenon headlamps
    By miked8887 in forum 1999 - 2006 (E46)
    Last Post: 07-20-2007, 10:02 PM
  5. WTB: 2004 330ci bi-xenon controle unit(s) NEEDED
    By custom in forum BMW Parts Wanted
    Last Post: 08-17-2004, 10:18 PM
