Results 1 to 6 of 6
Thread: Belt removal
    Oct 2008
    Millbrae, Ca
    1987 325i
    Belt removal
    Hello I am trying to replace my water pump on my 1999 323i and cannot figure out how to get the belt off properly. I've read about the tensioner and that i need to loosen the nut behind it however I can't seem to figure out how the heck to get to it. Any help would be greatly appreciated. Thanks in advance
    Oct 2005
    Canberra, Australia
    93' Turbo 325i Coupe
    Not sure if the 323 motor is similar to the 325i motor, but the tensioner usually has a dust cap over it with an M8(ish) Allen key bolt. Just pop off the dust cap and
    get the allen key in there and crank it to one side to release the tension on the belt. Do the same to reattach the belt.
    Jun 2010
    NY
    1997 328i
    Jun 2008
    Cincinnati, Ohio
    1995 and 1994 325iC
    Quote Originally Posted by dominator293 View Post
    Could be hex head or #50 torx, like mine. I took a pic with cell phone. You don't remove anything, just turn it to loosen.
    Thanks,
    Bob
    '95 325I Convertible Auto
    '94 325I Convertible 5sp.
    Jun 2010
    NY
    1997 328i
    Mine is a 16mm or 5/8" socket. Recently converted the tensioner to hydraulic and it came with a torx (star) bolt but I kept the original bolt.
    @dominator for the money shot, sexy sexy!
    Oct 2005
    Canberra, Australia
    Quote Originally Posted by Eric93se View Post
    Thanks, I try my hardest to always look good
  1. Drive Belt Removal Problem
    By deadboy in forum 1991 - 1999 (E36)
    Last Post: 03-19-2006, 06:35 PM
  2. 2001 740il seat belt removal help needed
    By HMBRKR in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-01-2005, 04:21 PM
  3. Belt Removal Help ASAP
    By 94325is in forum 1991 - 1999 (E36)
    Last Post: 08-17-2004, 03:24 PM
  4. Small AC belt removal (can it be removed permanently)
    By egeisert in forum 1992 - 1999 M3 (E36)
    Last Post: 05-23-2004, 06:36 PM
  5. Belt Removal Trouble
    By quickslvr387 in forum 1991 - 1999 (E36)
    Last Post: 08-20-2003, 03:59 AM
