Results 1 to 4 of 4
Thread: Engine swap help
    Jun 2019
    So cal
    BMW
    Engine swap help
    Will a 2000 323ci engine
    Work in a 2005 325i?
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    The 2000 323i came with an M52; the 2005 came with the M54. It can probably be done but you'll likely need other electronic parts. Probably best to find the same engine. I could also be very wrong.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What he wrote! The engines are very similar mechanically speaking but the electronics are very different.
    Jun 2012
    New Mexico
    2003 328i
    The engine itself is almost identical. Use your intake manifold and swap over your old coolant temp sensor just in case it is different. The crank sensor is supposed to be different but I have not seen one that didn't plug right in yet.
    The only issue I had installing an M52TU into an M54 car was that the spark plug tubes are a smaller diameter in the M52TU head. The pencil type coils used on the M54 are larger in diameter and although they fit right in you may find a DTC for ignition activation if the coil body is contacting the cylinder head.
    You can solve that issue with a set of rubber coated coils from a later e60/e90 if necessary.
  1. e28 Engine Swap help
    By modifiede30 in forum 1988 - 1996 (E34)
    Last Post: 10-04-2003, 08:10 PM
  2. Engine Swap Help!!!!
    By BzAlwayzLit in forum 1991 - 1999 (E36)
    Last Post: 04-03-2003, 01:20 PM
  3. Engine Swap Help!!!
    By BzAlwayzLit in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-02-2003, 08:04 PM
  4. Engine Swap Help!!!
    By BzAlwayzLit in forum 1992 - 1999 M3 (E36)
    Last Post: 04-02-2003, 01:40 AM
  5. Engine swap help + SC
    By Mitch P. in forum Forced Induction
    Last Post: 01-08-2003, 05:40 PM
