Results 1 to 4 of 4
    Los Angeles, CA
    '06 BMW Z4 M, '06 X5 4.4
    A/C Service Port?
    Hello I took my E53 in to a gas station to charge it up with freon (yes there is a small leak that nobody could diagnose) and the tech said I need a new A/C Service Port. Are those known to go bad in BMWs?
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    It's just a Schrader type valve. They can leak, but they're cheap.
    A small leak that nobody could diagnose? Sounds like you need to find a new repair shop. Leaks are not hard to find.
    And you're taking it to a gas station to have some refrigerant put in? Maybe that's part of the problem.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by sagdast View Post
    What was the context (more of the back story as to how they came to this conclusion) of "you need a new AC Service Port"? Is this where they found the leak?
    If you need to replace the Shcrader valve (for the suction line...which is were you connect for recharging with new refrigerant etc)...you can purchase those by finding an online vendor ...just type BMW xx xx x xxx xxx" (where x=the actual BMW part nbr) into a google search box...or order it from your local BMW dealership.
    You can find the 11 digit BMW part number (to use in place of the Xs bolded above) by looking it up in one of the online part databases. It's #10 in the diagram below:
  1. E31 R12 A/C High Side/Low Side Service Ports Reversed?
    By mjrgroup in forum 8 Series (E31)
    Last Post: 07-09-2015, 02:32 PM
  2. Replacement low pressure A/C service port cap?
    By shdowflare in forum 1995 - 2001 (E38)
    Last Post: 06-08-2012, 10:23 PM
  3. Service port CEL code flash paper clip trick...which ports
    By Yarko325is in forum 1991 - 1999 (E36)
    Last Post: 10-05-2010, 10:28 PM
  4. AC low side service port...loose?
    By ozzie540 in forum 1996 - 2003 (E39)
    Last Post: 03-25-2010, 08:49 PM
  5. E36 Diagnostic port cap (service port dust cover) OBDI E36
    By fiveightandten in forum Engines, Performance Parts & Software
    Last Post: 02-07-2010, 09:41 AM
