Results 1 to 8 of 8
Thread: Engine Support
    Dec 2002
    Darien, CT
    00' M Roadster, 07' Mazd
    Engine Support
    Can someone please advise the torque spec for the four bolts the mount the engine support to the engine block? Also, is there supposed to be any thread sealant used in this location?
    I've been chasing an oil leak on the passenger side of my motor for some time now. While running the engine with the car up in the air, I finally found that oil was bubbling out from the lower two engine support mounting bolts. I can also see a telltale sign of oil running down and back from this location. I don't recall removing this support arm previously but, I might have loosened the bolts when replacing the engine mounts.
    Thanks in advance for any help.
    -JohnK
    2000 M Roadster
    Estoril Blue, Black Top, Grey & Black Interior
    Mr. M Car reinforced rear subframe, VAC Oil Pan Baffle, Achilles Oil Pump Shaft Kit & Reinforced Oil Pick-Up Tube, Conforti Shark Injector, H&R/Bilstein, Swapped strut hats, IE subframe bushings, H&R Front/Rear Sway Bars, BW engine mounts, BW camber shims, CL Strong Strut, GC End Links, GC RSM, UUC short shift, UUC TME, UUC Clutch Arm Bushing, UUC Clutch/Brake line, Aluminum T-stat housing, S54 radiator and oil cooler, Stewart water pump, lower temp T-stat/fan switch, Aluminum Pedals, Z3 Solutions Trunk Organizer, Leather Z oil distribution block, LeatrherZ armrest, LeatherZ illuminated ZHP shift knob, Clear Bumper Lights, BMW 6 disc, Axxis Deluxe Plus, Doug Whalen seat bushings, Soundgate SDSBMW
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    Sorry don't have a manual to look up the spec right now. It's been a long time, but I don't recall those holes being open to an oil passage. You may have more of a problem than a simple re-torque.
    Good luck.
    Dan "PbFut" Rose
    Yeah those holes should not go into an oil passage.
    If the lower bolts are indeed loose, the bubbling may be a result of the oil behind the mount (from a source above, hopefully...) being squeezed out as the engine is running and shaking the arm. If so, I would remove the arm, clean the oil from underneath and off the threads, then re-tighten. I don't use a torque spec for those personally, just very tight.
    Is there oil under the driver's side mount only, or under the pass side mounting arm too? I assume you have checked all other obvious sources of leaks (VCG, OFHG, etc)
    PRICE CUT on ALL FABRICS
    Dec 2002
    Darien, CT
    Oil under passenger side only. Drivers side is dry. I replaced the valve cover gasket fairly recently and is bone dry. Based on the general location of the leak, I had expected it to be the timing chain tensioner but, that's dry too. All the other common leaks (oil filter housing gasket, dip stick grommet, oil pan gasket, etc.) were done as part of other recent projects. I wouldn't believe it either if I didn't see oil bubbling from those lower bolts with my own eyes.
    Edit: I'm not that good with the TIS, but, looks like the M8 8.8 bolts call for 24 Nm which, is not much at all.
    https://www.newtis.info/tisv2/a/en/e...ations/5gDQK89
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Twenty-three Newton-Metres, off the top of my head (that's the value for nearly all the M8 bolts on your car; something like 18 Ft-Lbs, if you subscribe to that sort of thing.
    Do verify that the cap for the timing chain tensioner is tight__32 mm wrench required; I tighten that on nearly every car that comes in here (just like torquing the upper strut bearing nuts__they're ALWAYS less than tight__23 Nm for them too).
    Dec 2002
    Darien, CT
    You guys were right as per usual. I removed the bolts and the threads had no oil on them. The oil leak must be from above the engine support bracket.
    The valve cover gasket is dry so, not sure what is going on here. The search continues
    SW Florida
    Quote Originally Posted by killeen_john View Post
    (Hint: the 32 mm wrench...)
    Dec 2002
    Darien, CT
    Sorry, I forgot to mention that I snugged that down too. I'll run it up in the air again tomorrow and see if still leaking. Thanks again for the help.
  1. My 3 dollar engine support.
    By ///MacDaddy in forum 1992 - 1999 M3 (E36)
    Last Post: 04-26-2005, 07:25 PM
  2. engine support
    By ebxgsxr in forum Middle Atlantic - US
    Last Post: 03-31-2005, 09:37 AM
  3. Engine support for removing transmission?
    By uoYkcuF in forum 1991 - 1999 (E36)
    Last Post: 02-07-2005, 04:46 PM
  4. Engine support question
    By M-Theory in forum 1991 - 1999 (E36)
    Last Post: 10-08-2003, 09:20 PM
  5. Engine support tool & jack plate
    By Jgent in forum 1992 - 1999 M3 (E36)
    Last Post: 06-06-2002, 12:32 PM
