Results 1 to 4 of 4
Thread: E46 Headlight Issues
    Mar 2019
    Las Vegas, NV
    1993 525i
    Hello all,
    I am having an issue with my e46's Xenon headlights (2003 325i, 128K miles, everything factory). I have searched through tons of posts about Xenon headlight issues, but have not been able to find anything similar to what I am experiencing.
    Upon startup, when I turn the headlights on, the passengers side raises and illuminates as expected. However, the drivers side does not turn on. Shortly after, I will get the code on my dash.
    Now, if I drive the car for a while with the headlights switched on, then turn them off and back on a few times, I can sometimes get the drivers headlight to come on.
    When I park the car at a store, run my errands, and come back out to the car/start it back up and turn the headlights on, the passengers side will come on as normal, then a few seconds later the drivers side will flash to life! So far, shutting the car down for a while and restarting has worked nearly every time.
    After I get the drivers headlight to finally wake up, it seems to work perfectly. No flickering/flashing or turning off.
    The passengers side seems to flicker at pretty much all times.
    I replaced the bulbs the first time I noticed the drivers headlight out, and have checked all the wires/connections, all seems fine.
    Anyone had a similar issue?
    Thanks!
    Eric
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E46 forum
    Jan 2016
    Ca
    2001 525it
    I would check for faults or swap the modules from left to right if the problem follows the move then one of the modules is faulty
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    In for more info here:
    When you say the headlight on the driver's side doesn't move down, then up this is at the very first start correct?
    If this is so, there is a leveler motor built into the headlight, and I don't think this has anything to do with shutter or bulb.
    Of course if you are getting flickering or failure for the lamp to come on, move the ballast from one side to the other.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. Headlight issue on 2003 E46
    By OddJungle in forum Lighting sponsored by BAVToys
    Last Post: 02-09-2016, 10:48 PM
  2. 2003 E46 headlight issue
    Last Post: 11-09-2015, 08:44 PM
  3. E46 involved in accident, repaired, replaced new headlight...issues
    By OneImprezziveRS in forum Lighting sponsored by BAVToys
    Last Post: 02-25-2009, 11:40 AM
  4. E46 Headlight Issue
    By Manny Lamancha in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-07-2004, 11:47 AM
  5. E46 Headlight Issue
    By Manny Lamancha in forum 1999 - 2006 (E46)
    Last Post: 07-06-2004, 02:37 PM
