Results 1 to 3 of 3
Thread: Replaced headlight adjusters on Driver side-Xenon headlight assembly
    Oct 2012
    Mansfield
    07 CX-7
    But seems light pattern seems off as I can see the cut off line on beam pattern in front of me.
    At startup, it does get slight adjustment movement and you see the headlight pattern move up ever so slightly.
    Anything else I should be looking at?
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    Did you manually re-adjust headlights after replacing the adjusters?
    There is likely some auto-leveler mechanism attached to your suspension that will make a minor adjustment. I am not too familiar with it. Your's are probably frozen. have a look from underneath near passenger and driver's front suspension.
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    The reason you replaced your adjusters is so that you can adjust your headlights. You now need to adjust your headlights. Use google as a resource for how. If you're not comfortable doing it yourself take it to a garage that can do it for you.
  1. E46 WTB E46 drivers side Xenon headlight assembly self-leveling fully working
    By BMWAccelerator in forum Exterior Lighting & Body Parts
    Last Post: 02-06-2014, 06:49 PM
  2. Replies: 4
    Last Post: 02-04-2014, 06:57 PM
  3. E65,E66 2002-2005 drivers side xenon headlight assembly, as is
    By JSanders in forum Exterior Lighting & Body Parts
    Last Post: 11-18-2012, 02:05 PM
  4. BMW E38 7 series driver side Xenon headlight complete. $250
    By mihai77 in forum Exterior Lighting & Body Parts
    Last Post: 07-03-2008, 09:02 AM
  5. E38 7 series driver side Xenon headlight complete. $250
    Last Post: 06-29-2008, 05:26 PM
