Results 1 to 6 of 6
Thread: iDrive button controller replace or fix?
    Oct 2014
    United States
    2012 F30
    Greetings friends. My iDrive button is sticking. Like someone spilled coke or something down it. My wife and daughter both deny, deny, deny but that's a whole other thread. Anyways been thinking about replacing it (find something on ebay) or try cleaning it. Anyone else ran/done this with their F30? What did you do? Replace or clean?
    Thank you in advance
    RC
    I always replace them here at work. The last thing you want to do is spray another liquid (cleaning solvent) all over it. And when I have tried it in the past, it never lasts long and always comes back.
    Jul 2004
    Houston, TX
    36 Cylinders
    If you have the widescreen navigation (called NBT) you can use this as an opportunity to upgrade to the touch controller with the bigger dial.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2014
    United States
    2012 F30
    Again thank you for the replies. Yes I've seen this upgrade to the bigger dial. Don't necessarily need it but I've considered it.
    So now WHERE to get a replacement? I'd be ok with just getting the same one just so long as it doesn't stick. It's pretty annoying.
    Jul 2004
    Houston, TX
    36 Cylinders
    I would identify which navigation system you have first. The bigger dial one isn't meant for the CIC system (not wide screen), but rather the widescreen NBT system. They have many differences.
    Sometimes ebay is a good place for used parts, sometimes the local junk yard. These aren't expensive.
    -Abel
    Oct 2014
    United States
    2012 F30
    Thank you for the replies.
    Looking around now for a replacement part.
    Thanks again.
  1. How to replace and fix your peeling start stop button VIDEO!
    By TiggeR540 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-29-2018, 08:13 PM
  2. Idrive Controller replacement, PN inquiry
    By Redu in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-05-2017, 12:45 PM
  3. Idrive Controller replacement, PN inquiry
    By Redu in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-04-2017, 12:32 PM
  4. Airbag Controller Replacement
    By M3inSC in forum 1991 - 1999 (E36)
    Last Post: 04-09-2004, 04:09 PM
  5. 18 Button OBC Replacement for 11 Button?
    By Androulakis in forum 1991 - 1999 (E36)
    Last Post: 12-05-2003, 08:46 PM
