Results 1 to 12 of 12
Thread: [CODING][ME7.2]Anyone changed AIMV in ecu ? (Wheel speed pulses per km)
    May 2017
    Poland
    e30
    Hello, as title say i have question if anyone changed this variable.
    Found out that AIMV in me7.2 is 24161074 but i have no idea why this number is so high. Also i have to put my number of pulses which is 468 for 17" 215/40/17 wheel in bmw e30
    May 2018
    Austin, TX
    00 M5 | 03 540i | 94 NSX
    Where are you getting these numbers? If you got them from a binary then it sounds like you're using the wrong XDF file.
    Jun 2018
    Castle Rock CO
    1990 325is, 1998 740i
    According to the data sheet FNRAD is the pulse between wheel rotation translated to speed so the two items most likely will require editing in tandem IMO I attached the pages from the function sheet that outline the two items
    AIMV is calibration pulses
    I like to pretend I know stuff
    Jun 2018
    Castle Rock CO
    the OLS I have for this DME also shows that crazy value for AimV
    I think the OLS shows this in the wrong spot if you look at both Damos files it shows the Aimv as a value equaling 2670.0000134 or 0X19B7914
    May 2017
    Poland
    e30
    Quote Originally Posted by zarboz View Post
    Thats the problem i guess, i have the same damos files, anyone found correct address for speed pulses ??
    Jun 2018
    Castle Rock CO
    what I am saying is the OLS is wrong the damos is probably right
    most the time it is the other way around I will see what I can figure out for you on this maybe because i am curious as well
    my mph is about 3-4 miles off and its annoying
    May 2017
    Poland
    e30
    Oh thanks lets figure it out
    You could adjust 4-5mph by FNRAD, aftermarket wheel size ?
    -edit-
    Found something about AIMV but in ME9 ecu:
    May 2017
    Poland
    e30
    still don't get it ... see attachement above ME9, they factor it and still shows some huge numbers T_T
    @bump
    Anyone ?
    Jun 2018
    Castle Rock CO
    Quote Originally Posted by Kisu1337 View Post
    @bump
    Anyone ?
    The motronic receives the signal conditioned by the trip computer with 4 impulses per revolution transmission wheel.
    This approx. complies to a frequency of 1 Hz per km/h. (Exact adjustment is performed by means of data; see
    signal conditioning AIMV).
    In the 10 ms grid a raw speed VROH is conditioned from the time difference between the two latest time entries
    delta-T = [ t(n-1) - t(n)], to which the fixed value AIMV is subject to:
    vroh w [km/h] = constant / AIMV [Imp./km] / delta-T [s]
    This value vroh w is limited into positive and negative direction by the change limitation DVFZBEG and
    stored in the RAM-cell vfzroh w.
    If delta-T becomes greater than 1 s, then vroh w is set to 0.
    With V > 0, vfzroh w is valid after 2 V-impulses.
    In the hold phase (KL 15 off) a V-acquisition is no longer performed, the V-value acquired last is preserved.
    For FGR-function vfzroh w is smoothed by a PT1-filter. The vehicle acceleration is calculated from the filtered speed
    signal.
    so AIMV is a part of a math equation and appears to be just a dividing factor
    read the screenshots I attached it breaks down the function and how it works
    ALSO please refer to the FNRAD posting I have shared.... it is the calculated vehicle speed against wheel pulse
    I asked on cartechnology but why do you want to change AIMV and who told you to start looking there?
    I am curious what your end goal is
    I know you said you had an m62tu in a e30 i wanna say
    Jun 2018
    Castle Rock CO
    Or maybe use math from your screen shot
    if hptuner shows @ 38,721 for 19152120
    then
    38,721 / 19152120 =
    0.002021760515285
    so X * 0.002021760515285 is your factor
    (if you want your output to match the way HP tuners seems to show it)
    I could have my maths backwords but I gave it a shot
    May 2017
    Poland
    e30
    DSC converts signal received from wheel magnetic ring Then sends square wave to ECU which sends to Instrument Cluster or being used in Cruise Control etc... I want to use it in e30 in which ABS output signal from sensor in rear axle shaft is square wave but with different frequency, i want to adapt my ecu to that signal
    Jun 2018
    Castle Rock CO
    I understand more now
    I think AIMv as well as FNRAD will need to be manipulated I replied to your PM so you can inspect the function sheet for more in depth information
  1. anyone change the manual transmission fluid themselves?
    By rpM in forum 1992 - 1999 M3 (E36)
    Last Post: 03-17-2010, 10:30 PM
  2. Anyone know where the ECU is located and how to change it?
    By serbstyle in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-16-2004, 08:09 AM
  3. Anyone change out their final drive for a 3.46
    By Gene V in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-05-2002, 12:27 AM
  4. Anyone change their instrument cluster on a E36?
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 03-12-2002, 07:02 PM
  5. Anyone change out their final drive for a 3.46?
    By Gene V in forum 1992 - 1999 M3 (E36)
    Last Post: 03-01-2002, 11:49 AM
