Originally Posted by
Mr. Bill
After a lot of reading and research here, I decided to inspect the release lever's connection because it didn't seem to have any resistance when I pulled the lever. Sure enough. I found the cable wasn't connected to the lever. Closer inspection revealed that the cable had frayed at the end causing it to fall out of the lever. So I grabbed the remaining cable with a pair of pliers, crossed my fingers and pulled. Voila! The cover latch released and I was able to lift the tonneau cover up and put the top in the boot.
Now all I need to do is figure out how to replace the cable and I'll be good to go!
