RM European Auto Parts
Results 1 to 6 of 6
Thread: No start, error codes, need help troubleshoot
    Jan 2015
    Atlanta, GA
    2004 BMW 545i
    Dear all, this my first post since joining. I have a 2005 545i with SMG. After one morning of “no start”, the car sat for a while which drained the battery. I have now charged the battery to 100% and it is being maintained with the trickle charger so I can performed diagnostic. Using a Foxwell NT520 I retrieved the list of code below. I am very handy but need help and guidance with understanding and how to proceed by elimination to fix the various codes. Someone please help!
    Vehicle: /scan/BMW/
    Test Path: BMW, Automatic selection, Auto Scan
    Status Report
    2E8B DME: Intelligent battery sensor, signal present
    2A67 DME: Valvetronic, actuator motor: activation present
    2A68 DME: Valvetronic, actuator motor 2: activation present
    2A6A DME: Valvetronic, actuator motor 2: power supply present
    2DD8 No message, receiver DME, transmitter Active Steering present
    51B3 Implausible message, engine oil temperature, receiver EGS, transmitter DME-DDE present
    4EF9 SMG: Clutch speed sensor not present
    51B1 Implausible message, wheel speeds, rear axle, receiver EGS, transmitter DSC not present
    4FB5 SMG: Control unit: internal fault (A/C converter) not present
    4FB2 SMG: Control unit: internal fault (watchdog) not present
    4E26 SMG: Solenoid valve, clutch not present
    4E91 SMG: Hydraulic-pump relay present
    4E21 SMG: Solenoid valve, gear selection, fuel injector 2 not present
    4F73 SMG: Gearbox: gear deselection unsuccessful not present
    CF07 Transmission control unit: Communication fault: PT-CAN not present
    5EAF DSC: DSC sensor, internal not present
    D35D No message (active steering, 0x1FC) present
    E484 SMBF: K-CAN line fault present
    E444 SMFA: K-CAN line fault present
    E244 SZM: K-CAN line fault present
    A468 CID: External open circuit (LVDS data line) present
    E5C4 CID: K-CAN line fault present
    D944 DWA: K-CAN line fault present
    9C54 IHKA: AUC sensor present
    E704 IHKA: K-CAN line fault present
    9C55 IHKA: Fogging sensor present
    A548 Message (Active Steering, 0x1FC) faulty, receiver KOMBI, transmitter AFS present
    E104 KOMBI: K-CAN line fault present
    E584 KBM: K-CAN Line fault present
    930C LM: Clearance light, left (E60, E65), outer (E60 Halogen), faulty present
    E504 LM: K-CAN line fault present
    DA04 SHD: K-CAN line fault present
    Jan 2016
    Ca
    2001 525it
    To many faults clear them all and start over also just because you charged the battery does not make it good, how old is it and did you load test it
    Jul 2004
    Houston, TX
    36 Cylinders
    Does it crank at all?
    SMG problems can stop the starter from cranking.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2015
    Atlanta, GA
    2004 BMW 545i
    No it does not crank at all. I do hear some clicking noise, which sounds like it is coming from the passenger side
    Mar 2008
    Coquitlam, BC, Canada
    2003 530i
    Clear the codes and re scan. Those remaining are hard faults, which indicate faulty wiring, sensors, and/or dead and unresponsive control units.
    Sent from my LG-H915 using Tapatalk
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I bet the battery is toast. That clicking sound is from the starter. I bet the voltage at the starter drops to zilch when you try to start the engine. That starter takes a bunch of power. Electrical power is measured in watts. Watts=voltage x current (measured in amps). If the voltage drops the starter tries to draw more amps to compensate. But the battery can’t provide the required amps. Have the battery tested for cold cranking amps.
  1. Transmission Program + Error Code NEED HELP
    By TJ21 in forum 1988 - 1996 (E34)
    Last Post: 09-21-2023, 04:37 AM
  2. No start, I have many error codes, need help troubleshoot
    By camido62 in forum Diagnostic Software
    Last Post: 06-16-2019, 01:32 PM
  3. Error codes, needing help!
    By CrilleB in forum 1996 - 2003 (E39)
    Last Post: 05-13-2014, 12:25 PM
  4. Error Codes....need help
    By wil137 in forum 1999 - 2006 (E46)
    Last Post: 08-13-2012, 02:23 PM
  5. Throttle Body and error codes -NEED HELP!!
    By Only1WithA323I in forum 1999 - 2006 (E46)
    Last Post: 03-07-2008, 10:43 AM
