Results 1 to 5 of 5
Thread: Check Engine Light In 1st and 2nd gear
    Jun 2019
    Poland
    2004 BMW 525D
    Hello,
    I recently purchased a 2004 BMW 525D while in Europe. The car has around 200,000 miles on it. I noticed sometimes when shifting into first gear that if I do not give it a lot of gas, occasionally the car goes into an engine fault low power mode. It also does this going from first to second gear as well. Sometimes I have the rpm up to 3k to prevent this from happening. Occasionally it happens in reverse as well. Then it has its days where it doesn’t go into engine fault at all. Once it goes into engine fault mode, I turn off the car and the mode is gone. Just finished driving a 600 mile round trip and car seems fine. All the filters and fluids have been changed and flushed. I’ve read it could possibly be a problem with the battery or even needs a software update. Tomorrow I’m going to check the codes when it goes into engine fault mode. Open to any and all suggestions! Thank you in advance.
    First time owner,
    Brad Waldow
    Mar 2019
    Phoenix
    i10
    Hi.
    For start, do you have an automatic gearbox?
    What check engine light does come on? A classical, small one in the instrument cluster, or the big 'half yellow' engine light on the central instrument display?
    For anything more specific, you really need to read the codes. I would suggest buying some kind of a scan tool. There are many cheap ones that will do the job.
    With 15 years old BMW, you will need it frequntly .
    Jun 2019
    Poland
    2004 BMW 525D
    Hello,
    It’s a manual one. And it’s the big half engine light. But each time it happens I just restart the car it goes away. I’ll try and check the code today and get back to you! Thanks!
    -Brad Waldow
    Jun 2019
    Poland
    2004 BMW 525D
    Hey,
    I tried changing the fuses and seeing if that helps with anything. Thinking it might be a fuel pump issue. Have to wait a few days for a mechanic to check. Europe stinks lol
    May 2017
    Houston
    03' 540i, 05' 545i
    Did you ever get those codes?
  1. [HELP!] 2007 Z4 Check Engine Light After 1st Week Purchase
    By Peppersteak122 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 12-29-2008, 09:39 PM
  2. Help check engine light one at 3K in 1st, 2nd and sometimes 3rd
    By Phatfred in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-15-2008, 01:06 AM
  3. Check Engine Light Between 1st and 2nd
    By MR2Rocket in forum 1992 - 1999 M3 (E36)
    Last Post: 04-08-2006, 11:00 PM
  4. Check engine light on in first gear?
    By krisko in forum 1992 - 1999 M3 (E36)
    Last Post: 02-24-2004, 11:46 PM
  5. Replies: 1
    Last Post: 06-26-2002, 12:55 PM
