Results 1 to 22 of 22
Thread: Bilstein B12 part#46-188106 OE Strut bearing and accessories dont' fit
    Jul 2018
    Brantford, Ontario
    1991 850I & 2014 ML350
    I'm new to the forum. I have been lurking for quite sometime and have bought WOKKE chip and just recently the rear wishbone bearings (BMW does not have this part).
    Lots to learn yet, but I decided to redo most of my rear and front suspension. So far, I have encountered a few challenges, but overall, I hope to have it done soon.
    Latest is that the B12 kit I bought inserted and threaded fine into the strut assembly, but the shaft at the top is 625 diameter compared to the 550 of the original. So the strut washers, strut bearing and other accessories will not fit. I am thinking of drilling out on a press to the 625 to make it work, but I'm not sure if there are replacement parts that will actually fit...or possibly, has the company I purchased from sent me the wrong strut inserts?
    Just looking for confirmation.
    Nottingham, UK
    E31, E36/7, E61
    Although the damper shaft is bigger diameter, the top threads are the same, so all stock parts should fit.
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    i had no problems installing a new kit Bilstein & Eibach springs... but aren't those B8 Bilsteins ???
    Jul 2018
    Brantford, Ontario
    This might give a better indication of the issue I am having. It goes over the threads, but no further. I would need to drill out to 5/8”.
    Jul 2018
    Brantford, Ontario
    Nottingham, UK
    E31, E36/7, E61
    Not replacing the top mount while your there?
    What PN is that one, 31331139436, is the correct part.
    Nottingham, UK
    E31, E36/7, E61
    Correct, B8 shocks come in the B12 kit.
    Jul 2018
    Brantford, Ontario
    I’m happy to replace the shock mounts...just can’t seem to get a straight answer on the kit needed...the B12 kit will not fit the OE top mount or washers. That’s my issue.
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    If I remember correctly, the top mount fits on the collar at the end of the threads, exactly as the picture on your post #4 above.
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    Jul 2018
    Brantford, Ontario
    Quote Originally Posted by rogbmw View Post
    This is as far as it goes...to the first taper and there is no thread protruding to fasten the top hat.
    Nottingham, UK
    E31, E36/7, E61
    The B12 kit for an E31 will fit all stock parts.
    Only two possibilities:
    1- Your kit is not for an E31.
    2- Your top mount is not for an E31.
    If you give me a few hours I will measure a stock top mount inner diameter so you will know 100% that you have the wrong kit.
    Calgary, Canada
    '91 E31 850i,'05 E53 4.4
    Hi OP< can you post the year of your 8 please? I had the SAME problem. WHen I bought my car (03/90 build date), I brought to a mechanic and he ordered the Billstein shocks and some new strut mount bearings too (just to refresh things) and it all installed fine.
    A few years later, I had to replace the strut mounts (sheared the mount when I hit a massive put hole) and when I ordered the strut mounts for my model year (03/90 build), the diameter for them was too small for the strut mount rod (same as you are showing in your pics), so I had to return them and buy ones for a 1994 or 1995 year (or something). When I received those, then the diameter of the strut mount FINALLY fit over the Billsteins again. So it was news to me. I'm just glad BMW allowed me to return the OE part even tho it was the official part number for my car, but because of aftermarket parts installed it no longer fit.
    I swear, my cars are like a girlfriend.
    Sometimes its a rough ride, sometimes its smooth motorin'.
    Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
    BUT at the end of the day, she loves it when I am inside her.
    Jul 2018
    Brantford, Ontario
    Quote Originally Posted by e31gixxxer View Post
    That would be fantastic My E31 is 1991 .
    Jul 2018
    Brantford, Ontario
    Quote Originally Posted by clockwork View Post
    Hi OP< can you post the year of your 8 please? I had the SAME problem. WHen I bought the car, I bought the Billstein shocks and then some new strut mount bearings too and installed fine. a few years later I had to replace the strut mounts and when I ordered the strut mounts for my model year, the diameter for them was too small, so I had to return them and buy ones for a 94 or 95 year and when I received those, then the diameter of the strut mount FINALLY fit over the Billsteins again.
    Mine is 1991....you may be on to something..maybe there was a diameter change in later model years?
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    What's odd is the part number for later models is the same as the early cars, 31331139436. Seems like it should have changed if bore of bearing is different.
    Nov 2018
    Sweden
    1994 840ci
    31331135577 is the number up to 07/1990 at least on the eurospec cars.
    Up to that date the center nut for the damper is m12. After it's m14 so I think that is your problem.
    Calgary, Canada
    Quote Originally Posted by davidof View Post
    Exactly my problem.
    Sent from my Pixel 3 using Tapatalk
    Nottingham, UK
    E31, E36/7, E61
    The internal diameter of the hole on an original top mount from my car, which was replaced by PN: 31331139436 is 16mm or 0.630".
    Realoem says this PN is for cars from 07/90, so davidof has probably hit the nail on the head.
    A pair of new mounts and drill your washers out.
    Jul 2018
    Brantford, Ontario
    Confirmed buying new mounts, hole was proper size, drilled out washers..struts back on. I do agree with comments on the B12 kit..very firm, but I won’t know until I finish the rear rebuild...found out that the rear wishbone bearings are not available OEM. Ordered from Wokke...waiting for arrival.
    Jul 2018
    Brantford, Ontario
    Just wanted to update that the car is now drivable sits nice and drives tight. Before all the strut, shock , spring and bushings change, steering was sloppy and going around corners the car was wavering all over the place. Still need an alignment which is being done in a couple days. Thanks to Wokke for wishbone bearing which BMW never made the part available!
    Jan 2012
    Halifax, NS, Canada
    1994 BMW 840Ci
    Beautiful work on the car.
    Where are you at in Ontario? I'm way east in Halifax. Not another 8er buddy to be found for many miles.
    Jul 2018
    Brantford, Ontario
    Quote Originally Posted by Phinnman View Post
    Near Brantford Ontario...Halifax..hey, it’s only a 15-18 hour drive in a Grand Tourer ;.)
    Thanks for the kudos...hoping to do some more in the winter...getting a hoist was so worth it makes working on the car enjoyable.
  1. Bilstein B6 HD compared to OE struts on 2014 x3 without dynamic handling.
    By hhgolf in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 05-06-2014, 05:34 PM
  2. E30/E36 Parts (Bilstein, A/C, BBS, Chip, OE, etc)
    By RidingSimple in forum Exterior Lighting & Body Parts
    Last Post: 07-02-2009, 08:02 PM
  3. Replies: 1
    Last Post: 06-19-2008, 10:10 AM
  4. Bilstein HD + Eibach ProKit $ 450 RSM & Strut Bearing As
    By fporro in forum BMW Parts For Sale
    Last Post: 05-01-2006, 12:23 AM
  5. Bilstein HD + Eibach ProKit $ 450 RSM & Strut Bearing As
    By fporro in forum 1983 - 1991 (E30)
    Last Post: 04-01-2006, 06:21 AM
