Dear all, this my first post since joining. I have a 2005 545i with SMG. After one morning of “no start”, the car sat for a while which drained the battery. I have now charged the battery to 100% and it is being maintained with the trickle charger so I can performed diagnostic. Using a Foxwell NT520 I retrieved the list of code below. I am very handy but need help and guidance with understanding and how to proceed by elimination to fix the various codes. Someone please help!
Vehicle : /scan/BMW/
Test Path : BMW, Automatic selection, Auto Scan
Status Report
2E8B DME: Intelligent battery sensor, signal present
2A67 DME: Valvetronic, actuator motor: activation present
2A68 DME: Valvetronic, actuator motor 2: activation present
2A6A DME: Valvetronic, actuator motor 2: power supply present
2DD8 No message, receiver DME, transmitter Active Steering present
51B3 Implausible message, engine oil temperature, receiver EGS, transmitter DME-DDE present
4EF9 SMG: Clutch speed sensor not present
51B1 Implausible message, wheel speeds, rear axle, receiver EGS, transmitter DSC not present
4FB5 SMG: Control unit: internal fault (A/C converter) not present
4FB2 SMG: Control unit: internal fault (watchdog) not present
4E26 SMG: Solenoid valve, clutch not present
4E91 SMG: Hydraulic-pump relay present
4E21 SMG: Solenoid valve, gear selection, fuel injector 2 not present
4F73 SMG: Gearbox: gear deselection unsuccessful not present
CF07 Transmission contro unitl: Communication fault: PT-CAN not present
5EAF DSC: DSC sensor, internal not present
D35D No message (active steering, 0x1FC) present
E484 SMBF: K-CAN line fault present
E444 SMFA: K-CAN line fault present
E244 SZM: K-CAN line fault present
A468 CID: External open circuit (LVDS data line) present
E5C4 CID: K-CAN line fault present
D944 DWA: K-CAN line fault present
9C54 IHKA: AUC sensor present
E704 IHKA: K-CAN line fault present
9C55 IHKA: Fogging sensor present
A548 Message (Active Steering, 0x1FC) faulty, receiver KOMBI, transmitter AFS present
E104 KOMBI: K-CAN line fault present
E584 KBM: K-CAN Line fault present
930C LM: Clearance light, left (E60, E65), outer (E60 Halogen), faulty present
E504 LM: K-CAN line fault present
DA04 SHD: K-CAN line fault present
