Results 1 to 7 of 7
Thread: Current draw draining battery Z3 1997 1.9
    Mar 2008
    scotland uk
    e36 coupe
    Hi I seem to have a parasitic draw that's draining my battery. With everything switched off an amp clamp is showing a draw of 0.4 amps. Strangely though when I close the door and the interior light is on this current drops to almost 0 then, when the interior light dims and goes out, the current climbs back to 0.4 amps again. I've taken the interior light fuse out but the current remains constant. I'd be grateful for any suggestions as to why this is happening. Thanks in advance.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    If it goes to 0 when ~500 mA of lights are on, I would first verify the calibration and zero point on the amp clamp.
    /.randy
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Does you clamp have the option of using leads? If so I’d use them just to be sure. Your working with pretty low amperage. Most meters are good to 6-10 amps. What time frame is the battery going flat in.
    Mar 2019
    Phoenix
    i10
    Quote Originally Posted by davedougan View Post
    https://autofthings.com/best-battery-tender/
    Hello.
    To pinpoint the problem, try removing fuses, one by one.
    If during this you get a 0A draw, that will be the cirrcuit that is the source of the problem.
    After that, try eliminiating each component, one by one.
    Hope that will get you somewhere.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    The Z3 has a draw of about 40 mA when asleep to drive unlock monitoring , radio codes, clock etc. Don't expect it to go to Zero mA.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    Maybe this method will help. I’ve not tried it
    https://youtu.be/lRcj1fQcWwU
    Mar 2008
    scotland uk
    e36 coupe
    Thanks for the replies, I'll try the fuse switching method to try to pinpoint the module causing it. The battery takes about 5 days to drain but I've got it on a conditioning charger meantime.
  1. Current draw from the battery to the starter of E36
    By Franky goes in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-04-2019, 11:21 AM
  2. Battery Discharging overnight but small current draw?
    By 93e36beater in forum 1991 - 1999 (E36)
    Last Post: 02-25-2015, 05:56 AM
  3. Z3 E36/7 Z3 1997 BMW Cd/Radio player wanted
    By evangelos in forum BMW Parts Wanted
    Last Post: 02-03-2012, 02:06 PM
  4. Battery current draw
    By leshchuk in forum 1995 - 2001 (E38)
    Last Post: 04-06-2009, 02:45 PM
  5. Replies: 6
    Last Post: 01-13-2008, 07:13 PM
