Results 1 to 3 of 3
Thread: E46 won't start when warm
    Jun 2019
    Ireland
    E46
    Recently left my 03 e46 in to garage cause the fuel pump was starting every time which turned out to be an intermittent wire but since it's come back it starts when cold but when it heats up won't there's just a click it's not the starter any help guys wud be greatly appreciated thanks in advance
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Let me see if I have this correct: when the engine is cold the engine will start properly, but when the engine is hot all you get is a click. I think your starter is bad. However, do you have a digital multimeter? You need to check the voltage at the the starter when you get a click. Check it at the main power “stud” where the large red wire/cable connects to the starter. This should have battery voltage at all times. See if the voltage drops at all. As you’re in Ireland I’m assuming the car gas a 4 cylinder engine, so access to the starter should be fairly easy. Also, do you have a second key? Try it the next time the no start happens.
    Mar 2011
    PNW
    LS E46
    There may be a problem with the signal wire going to the starter solenoid from the DME box. I’ve had this problem on 2 e46’s and think it’s started happening on a 3rd. If you can feed 12v directly to the solenoid and the car starts, there’s your problem.
  1. e46 won't start in cold.
    By ACatoggio in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-05-2010, 02:57 PM
  2. E46 Won't Start Fuel Relay?
    By dcartelle in forum 1999 - 2006 (E46)
    Last Post: 02-15-2009, 11:23 PM
  3. Yet Another E46 Won't Start Thread
    By atrain76 in forum 1999 - 2006 (E46)
    Last Post: 06-08-2008, 07:09 PM
  4. 525d won't start when warm
    By pdriver in forum 1996 - 2003 (E39)
    Last Post: 05-22-2007, 04:56 AM
  5. Need Advices: 2001BMW e46 Won't start
    By PLTBMW in forum 1999 - 2006 (E46)
    Last Post: 12-05-2006, 12:55 PM
