Results 1 to 4 of 4
Thread: Car Jumpy at 1.5k - 2.5 rpm
    Jul 2014
    Bay Area
    1995 BMW M3 Coupe
    Hello Everyone,
    So I was trouble shooting a misfire that showed up after a car wash. My car shut down and wouldn't turn on for a day, I believed it was my DME unit so I replaced it. Car turned back on but would make popping sounds and would generally idle abnormally, This was especially bad when I drove it. The engine sounded really bad when accelerating.
    I decided to do a tune up changing spark plugs, coil boots, fuel filter, fuel injectors and a couple breather hoses. I would do one maintenance item then try running it to see if there was improvements.
    The car sounds much better now but there is still this slight loss of power, sort of a jerky feeling, when I'm accelerating from around 1.5k to 2.5k rpm. The jerking feeling doesn't last throughout this range but at specific points and only when I'm pressing the gas. I don't know what can be wrong, I'm guessing fuel pressure regulator? or a bad fuse? Either that or a compression issue.
    Just looking for ideas on what direction to head now... I hope it's sufficient to pass her up coming smog test
    Jan 2019
    Connecticut
    E92, E46, E36
    I had a VERY similar situation with my e46 a few years back, turned out to be the mass air flow meter. Maybe not your issue but something to consider
    Sent from my SM-G960U using Tapatalk
    Jul 2014
    Bay Area
    1995 BMW M3 Coupe
    Quote Originally Posted by Ctwide3project View Post
    I've heard of this being an issue. I'll try cleaning it out and if it gets worse I'll try replacing it. Thanks for your input
    Jun 2010
    NY
    1997 328i
    Possibly a vacuum leak.
  1. Code 1111, Hesitation, car cut out at 5k..
    By ecko457 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-13-2007, 12:50 PM
  2. Code 1111, Hesitation, car cut out at 5k..
    By ecko457 in forum 1991 - 1999 (E36)
    Last Post: 08-03-2007, 06:37 PM
  3. Flat spot/hesitation in the powerband between 5k and 6k rpms
    By Hugo in forum 1992 - 1999 M3 (E36)
    Last Post: 06-22-2006, 02:06 PM
  4. under load, car won't move passed 1500-2000 rpm
    By Idealist in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-15-2006, 10:13 AM
  5. car hesitating at 5.5k RMP?
    By joey95m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-27-2005, 02:04 PM
