Results 1 to 6 of 6
Thread: sls sensor
    Madison
    99 528it black 99 528
    sls sensor
    I have a 99 528 touring with the suspension light on. I have replaced the bags because they were original and also the right ride height sensor since i was getting a code for this. Since replacing the sensor i can not reset the sls light on the dash. I have read that the new sensor needs to be coded to the car before the light can be turned off. My question is how do i code the new sensor?I have access to inpa and know that the sensor is working by manually raising and lowering the height with the software. When i try to clear error codes i can hear clicking from the module in the rear.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    The new sensor shouldn't need any coding... perhaps you got a bad sensor? If the sensors are all good, just clearing the errors should be enough to get the SLS working again. The system's still unhappy about something.
    1995 525i 5-speed - Thread
    Madison
    I looked closer today at the old sensor. There was some corrosion on two of the pins. Now the question is how do i remove the corrosion from the connector? I am assuming there is some. Do i chemically spray it or remove the harness and buy a different one? i am thinking De-Oxit here. Also what should the volt values to the sensors be when the vehicle is at a standstill? I am thinking 0 volts.
    May 2018
    Florida
    '99 E39 M5T
    A contact cleaner would suffice. When I fixed my SLS, the compressor was dead (looked as if it was submerged in water) and my air springs were shot. I replaced the compressor and air springs, but the system still did not work, when I hooked it all back up. I found a video about doing a hard reset, and that worked. Disconnect the battery and turn everything on, in the car, that you can. I then let the car sit for about an hour. Came back, turned everything off, hooked up the battery and the compressor kicked on and aired up the car... No more SLS light.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    The same results can be done with disconnecting the battery (both terminals)! wait 20 sec an the connect the cable end together for 15 seconds.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Madison
    so i tried unplugging the battery for a few hours and that did nothing. Light is still on.Will have to do some more investigation on this one.
  1. SLS Sensors
    By RogerC493 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-11-2018, 07:33 PM
  2. FYI - SLS shop error / service mistake - sensor arms!
    By geargrinder in forum E39 Touring / Wagon
    Last Post: 06-23-2017, 05:29 PM
  3. Picture of rear SLS sensor connector
    By RodimusPrime in forum 1996 - 2003 (E39)
    Last Post: 02-22-2016, 10:02 PM
  4. Touring SLS Sensors
    By Rosski in forum 1996 - 2003 (E39)
    Last Post: 03-03-2012, 05:30 AM
  5. Level sensor, SLS
    By Fanatic1 in forum 1996 - 2003 (E39)
    Last Post: 11-10-2009, 09:50 PM
