This is the same guy who on a timing chain guide thread, told the guy wondering if he should do his guides, that if he dropped his oil pan, and there were no broken pieces of chain guides, that he didn’t need to do the chain guides..... That’s some stellar advice right there....
This really all those sensor do. One front, one rear. They do not show brake forces, temp, etc. They were engineered to resolve the clients who NEVER open a hood or have service work done until a "light" comes on. Think of it as an IDIOT light for brakes....
Can you hack them to stay off, Yes. Why you would is another conversation. One where the obvious answer should be Never. I think that solution area goes with duct tape.
Is PRICE an issue?
ULTRA-POWER5S8416{#34351163066} $2.39 www.Rockauto.com
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
Yep, it is the "idiot sensor".. No BS assistant needed...!! :-)
Well it did a stellar job, if its mission is to find idiots. It found me some and then more.
More reasons to keep it.
Diehard E39 driver.
I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
"Your momma's so ugly she makes Bangle cars look nice"
Hi jcaino,OP
I just tried both hacks on my car, to get rid of the gremlins. And they work.
On the front driver side, I yanked off the sensor from the pads, cut it with a scissor, then connected the 2 wires with a piece of electric tape. So the sensor is still on the car, but shunted from the pads. And a closed circuit.
On the rear right side, I completely removed the sensor and threw it away. Then I cut the wires at above the plastic cage box, as I am suspecting a bad connector. Then same procedure, separated the 2 wires and taped them with black electric tape to close the circuit. So, no sensor.
Test drove for 50 miles, There...no more "check brake lining" red light gremlins, and I will never hear again of that stupid "idiot pad sensor"....!!
My car doesn't do that. If you splice the wires together you still get the fault.
Maybe it's like the RDC where my car has the in-wheel antennas and US spec'd cars relay on the DSCIII comparing rotational cycles on the tires to guesstimate wether one tire's smaller or deflated. But the wear sensors are the same... so I'm dumbfounded.
Since I take meticulous care of my cars, I would consider the idiot light delete if it keeps on bugging me. Maybe, as you suggest, the corroded pin is is from the plug up, and that's why the system gets cranky and I don't get solid results splicing wires together.
Diehard E39 driver.
Diehard E39 driver.
Oh I just realized this started after I power washed the engine bay...
I'll have to chase a wet harness or plug or something. If anybody knows where are those wires routed to, I'd greatly appreciate the tip. It will save me hours of diggin thru wiring diagrams.
Diehard E39 driver.
Update: I can't quite solve this yet. It's getting annoying. I have a bunch of codes regarding the DSC module, CAN/DSC timeouts and such. The only thing I can find is that the brake sensor flicks on and off and sometimes it stays on with the IKE light next to the park brake light on. As you could foresee on a 20 years old brittle plastic bit, replacing several sensors caused the male connector (the one that stays in the body harness) to crumble to bits.
Is there a P/N or repair pigtail? If so, could somebody that has already gone thru this give me a P/N? Thanks.
The DSC module on my car is fairly new (got it in 2015 I believe, a new unit, and it was properly coded, and it's not showing any telltales of DSC module failures which I'm familiar with because I had to diagnose it when I changed it)
No jerky transmission operation, no traction control issues, some lag on acceleration and pedal position lazyness, but I do believe I can chalk that up to the early stages of throttle body failure (DBW - this is the '99 540i)
It's all peaches until you go over some uneven terrain or turn the steering into a tight corner and it gets nuts and starts to flicker the brake linings light on and off and on and off and sometimes it stays on, most of the time it keeps going on and off at larger intervals. I'm clearly having a sporadic short or grounding somewhere but I'm dumbfounded, as the only thing that I could do is remove the entire coverings and wiring harnesses going from the rear right and front left wheelwells to the e-box.
Diehard E39 driver.
Just my two cents. I had mine go off after getting my M Sport rear bumper put on. Totally unrelated right? One of the harnesses to the taillight was loose. As soon as that was firmly plugged back in, everything was good again. Doubt it helps in this case though.
2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
Diehard E39 driver.
