I m a new member whom have just bought a 525xi 2006 3.0l sedan while driving I just had an acceleration failure if I press the pedal no respond the engine running idle pls kindly help me out
Im jouro a new member to this forum and I'm experiencing throttle failure when engine start if I press the pedal there is no response from the engine pls kindly help me on what to do thanks 🙏
You need to have the codes read. There should be some errors that will lead you in the right direction.
