Results 1 to 7 of 7
Thread: E36 ride quality
    Wisconsin
    1995 BMW M3
    E36 ride quality
    My 95 m rides like a rock. I m thinking I need some new front suspension. Currently I have koni yellows in the back but stance coil over on the front. One of my coil overs I cannot adjust the damper because it is stuck and doesn’t rotate left or right. Those coil overs have adjustment on the bottom. Also, wondering about my rear springs. I think they are TC Klein and every time I jack off the car back I have to reset spring. Is this normal? Any suggestions for front suspension? I will eventually drive the car but more concerned with quality. I don’t I need to ride like a Cadillac but right now it feels like I don’t even have suspension, LOL
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There are about 31 bushings, ball joints, mounts and links under the car. The ones that are 24 years old are no longer doing a very good job. Typically adding stiffer shocks and struts and lowering the car with stiffer springs only makes things worse when the suspension needs work to start with.
    Oct 2003
    Seattle
    99 M3
    E36 ride quality
    Couple of ways to go here, Sachs produces OE replacement Struts (and rear Shocks.)
    Bilstien offers (at least) three levels of bolt on replacement Struts/Shocks, B4 (OE replacement), B6 (non-lowered Sport), and B8 Sports (for use with lowering springs).
    As for Springs, H&R OE Sports, and Dinan offer a ride comfort very similar to OE with a very slight drop.
    M3 OE Forward Lower Control Arms are a bit ‘spendy’, though folks have figured out the process of replacing the Ball Joints (search E36 Ball Joint). ..or simply replace theFLCAs with Meyle HD FLCAs.
    Replace the offset FLCA Bushings, and at least grease your Strut Mount bearings.
    Your Rear Trailing Arm Bushings probably need to be replaced. The RTA pivots thru multiple axis at this location, resist the temptation to use solid (Poly, Derlin) Bushings here.
    In the rear the 1995M3 was fit with a solid and a rubber isolated outer control arm bushing at the ‘knuckle’. The 1996+M3 uses two solid joints, do the same on your 1995M3.
    Jul 2018
    BC
    1998 M
    Sent from my CAT S61
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by crc13 View Post
    .....wondering about my rear springs. I think they are TC Klein and every time I jack off the car back I have to reset spring. Is this normal?
    There is a special RSM for really low car. Raises the Shock attach interface up a couple of inches so that you are riding in the sweet spot of the Shock and droop is less of an issue.
    I think they are from Ground Control and possibly Turner.
    FL
    are slow.
    Quote Originally Posted by bluptgm3 View Post
    Bluptgm3 knows what he's talking about.
    My M3 had these when I purchased it.
    https://groundcontrolstore.com/colle...nt=35511607747
    Don't use poly or delrin RTAB's. That is a crappy fix. Use OE bushings with delrin spacers. Make a threaded press to get them out, or buy the tool, air chisel, or even use a hammer and chisel to get the old ones out. Press in the new ones with a 60mm (I believe is the right size) t-clamp to compress the bushing, and press it in with a tool of your making or one you buy. The important part here is to pre-load them properly.
    Your shocks have a huge impact on how you perceive impacts on the road. Blown shocks will ride really poorly and feel like you're always crashing down on bumps. I would check for blown or leaking shocks all around, and also check your front lower control arm bushings for cracks, missing pieces etc. I would only replace these with OE rubber or the solid rubber centered ones PN# 31129069035 everything else should not be on the street.
    -Dr. Seuss
    Chicago, IL
    99 Dakar M3
    Yeah I had a night and day difference in ride quality when I replaced my shocks and struts as well as my control arms, control arm bushings, and end links.
  1. Lowered e36 m3 ride quality
    By AsifLicious in forum 1992 - 1999 M3 (E36)
    Last Post: 12-29-2014, 10:50 AM
  2. E36. How did your ride quality improve after changing control arms, sway bar bushes ?
    By lobe29 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-12-2013, 02:33 PM
  3. Best option to lower w/o sacrificing ride quality too much?
    By gorgerax in forum 1991 - 1999 (E36)
    Last Post: 11-21-2007, 06:33 AM
  4. 95m3 18 vs.17 ride quality
    By gurky325 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-27-2003, 09:49 PM
  5. Best shocks in terms of ride quality?
    By gaff in forum 1991 - 1999 (E36)
    Last Post: 09-23-2002, 04:58 PM
