Results 1 to 12 of 12
Thread: CD changer won’t play
    Jun 2012
    Long Island
    00 750iL 01 S8 96 Vette
    I have a 2001 750iL with DSP and widescreen monitor. All the sudden I can’t select the CD changer mode. When I press the “mode“ button, instead of cycling between radio—tape—CD, it just a cycles radio—tape—radio—tape, completely skipping CD mode. I’ve checked all fuses. What would cause this? Thx.
    WTB the following Highline/Individual parts for my 2001 750iL in Black (updated Apr 2016):
    -front sport seat-back cushion
    -rear U.S. entertainment armrest with radio/MID/seat/phone/shade/etc controls
    -rear digital climate control with rear blower and black leather housing/console
    -glovebox and rear right 2001 LHD 750iL wood trim with flag inlay; maybe the dash pieces too
    Ryan
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E38 forum
    Markham, Ontario, Canada
    2001 750iL
    Did you do some work in the trunk?
    Check the ibus connector at the CD changer. Perhaps it popped out.
    Jun 2012
    Long Island
    Quote Originally Posted by MJeffC View Post
    No work in the trunk. But I did check all fuses in the trunk and any related fuses under the hood - all seem OK. I also checked the connectors at the CD changer.
    Jun 2012
    Long Island
    i still stumped. CD mode wont play. (I've been using a DICE mediabridge for years via my CD changer connection). Not sure what to do anymore.
    Ryan
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Try re-setting your connection by simply unplugging the power plug (3-pin connector) then re-connect. I also get this error sometimes, and this trick works for me.
    Frankie
    Texas, USA
    frankies-bmw.com
    Jun 2012
    Long Island
    Quote Originally Posted by Frankie View Post
    Appreciate the tip, I will try that. Should the key be in the “on” position at all? Or should I also try disconnecting the battery, or a “battery nap” ?
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Quote Originally Posted by serious7series View Post
    ...Should the key be in the “on” position at all? Or should I also try disconnecting the battery, or a “battery nap” ?
    Nope. Just cycle the 3-pin power plug.
    Frankie
    Texas, USA
    frankies-bmw.com
    Mar 2014
    Iraq
    1998 BMW e38 740i
    I have similar problem with 98 740 , I fixed it
    It was a fuse in a small box underneath the cd changer , it was rusty .
    Jun 2012
    Long Island
    Figured it out. Apparently the connector at the DICE mediabridge was loose. I even checked that by disconnecting/reconnecting before I even started this thread. Oh well.
    Jun 2012
    Long Island
    While I was in the trunk checking the connections, I noticed that one of the wires (yellow w/brown stripe) from the blue connector at the back of the DVD nav unit was cut. Intentionally cut, presumable by the PO. Is there anything that might explain this? I do know that the PO upgraded to MKIV widescreen.
    Ryan
    Dec 2008
    Washington, NC
    01 330 CiC, 05 X3 3.0
    There was one wire I had to cut when I swapped to MKIV that was blocking audio due to a conflict between a MKII module that was eliminated when you go to MKIV. It was like the nav audio, I think.
    Incidentally, my Mediabridge will occasionally disappear, usually comes back on a restart.
  1. new cd player wont play cd
    By cruzr180 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-13-2006, 08:58 AM
  2. cd changer that plays CD-RWs
    By SynSyx in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-01-2006, 01:02 PM
  3. cd changer that plays CD-RWs
    By SynSyx in forum 1983 - 1991 (E30)
    Last Post: 05-01-2006, 12:59 AM
  4. CD changer stopped playing after dim display fixed
    By Riken in forum 1991 - 1999 (E36)
    Last Post: 01-01-2005, 03:46 PM
  5. CD Changer wont work.. someone please help!!
    By 325iGuy in forum 1991 - 1999 (E36)
    Last Post: 05-07-2001, 05:42 PM
