Results 1 to 8 of 8
Thread: e65 e66 SZL VIN Programming (Steering Angle Sensor)
    Detroit, Michigan
    Lotus Europa
    I'm having a heck of a time trying to change the VIN coding on a used SZL (Steering Angle Sensor) module I picked up for a 04 e66...
    I got closest with Tool32 and can read the current vin, but when I try to program it with the full VIN (all 17 characters) with the correct digit at the end, it isn't happy and doesn't take the change..
    It's out of an 04 745 and going into an 04 760...
    Is there a preferred tool for this operation? I even took it to a dealer with Autologic and they get some sort of message saying it's the wrong part #...
    Has some writing on the unit...
    Original: BMW 6938630 /3OS 01416788 /HW 010, /SW 6B0
    Replacement: /P BMW LZ 9 138 464-02 /3OS LK 01 4367 15-01 /HW 012 /SW 790
    Pete
    Jul 2004
    Houston, TX
    36 Cylinders
    Need more info on the cars.
    There was a change in steering angle sensors on production date 03/2004 for e65.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Detroit, Michigan
    Lotus Europa
    The 04 car it's going into has a 10/03 build date, I'm almost certain... not sure I have the other one. Any idea how to dig into it deeper without knowing the exact car it came out of? The 'new used part' has part no 61319138467 which should fit 760 04-06, 760Li 04-08...which my car does fall into...but that's just according to a couple parts reference sites...not sure of the exactness of that detail (or how they determined that compatibility)
    Jul 2004
    Houston, TX
    36 Cylinders
    61319138467 is from models built after 03/2004, so it is the wrong part number for your 10/2003.
    -Abel
    Detroit, Michigan
    Lotus Europa
    Thanks for that detail! Do you happen to have the part number for the earlier (10/03) cars? Think there’s any hope in getting this one to work or reprogrammed in some way? Seems really odd that this wouldn’t be somehow a superseded part and have a way to interchange... it looks identical but obviously something internal is different...
    Pete
    Jul 2004
    Houston, TX
    36 Cylinders
    BMW parts system, online:
    https://www.realoem.com/bmw/enUS/select
    Works best with the last 7 of VIN in the "Serial" blank and click search.
    -Abel
    Detroit, Michigan
    Lotus Europa
    It doesn't seem real obvious that it's not supposed to work, though...I see what you mean about there being multiple parts, but both parts mention they were used in the 7 series e66...does it typically list crossover parts for the entire series, or perhaps is there a TSB explaining this changeover? It's technically in the middle of a 2004 build year? And since I can't find the exact part number ON the part, i'm just trying to make sure I'm not giving up too soon
    Steering Angle Sensor - "Switch unit steering column"
    up to 3/2004 - 61316970833
    Supersedes:
    61310409991 (09/01/2005 — 12/13/2006)
    Part 61316970833 was found on the following vehicles:
    7' E65   (02/2000 — 07/2008)
    7' E66   (06/2000 — 07/2008)
    7' E67   (10/2002 — 06/2008)
    Phantom RR1   (07/2002 — 04/2012)
    FROM 3/2004 - 61319289173
    Supersedes:
    61319138467 (09/01/2006 — ), Bilaterally exchangeable
    61312298833 (12/01/2011 — 06/13/2013)
    Part 61319289173 was found on the following vehicles:
    Jul 2004
    Houston, TX
    36 Cylinders
    Don't go by those dates. Go by the dates on the page with the picture. It's clear that they say the transition is at 03/2004.
    -Abel
  1. E65 DSC SZL Steering Angle Sensor FIX. I hope.
    By grumman in forum 2002 - 2008 (E65, E66)
    Last Post: 01-14-2018, 11:22 AM
  2. SZL Steering Angle Sensor Reset Question?
    By ronreece in forum 2002 - 2008 (E65, E66)
    Last Post: 04-07-2015, 05:33 PM
  3. SZL Steering Angle Sensor Reset Question?
    Last Post: 04-05-2015, 02:12 PM
  4. wrong VIN on steering angle sensor
    By 20vector in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-26-2013, 04:49 PM
  5. Help - steering angle sensor E65
    By Milla in forum Diagnostic Software
    Last Post: 06-16-2013, 03:49 PM
