Results 1 to 25 of 26
Thread: Interesting Cruise Control Issue Happening
    Dec 2013
    USA
    1999 BMW MZ3 Roadster
    This has happened a few times now. I use my cruise control often. Lately when I step on the brake instead of turning the cruise off the car starts pulling forward wanting to accelerate. Obviously that is not good. Does anyone know what is going on?
    Dec 2013
    USA
    After a search it looks like it might be a switch related to the brake pedal. Does that sound right? How difficult is it to swap them out?
    birmingham,al
    2001 3.0 Z-3 RD'STER
    Quote Originally Posted by Kram71 View Post
    It could be the cruise control module actuator. That is my guess.
    Sent from my SM-G920V using Tapatalk
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    T... when I step on the brake instead of turning the cruise off the car starts... to accelerate...
    After a search it looks like it might be a switch related to the brake pedal... How difficult is it to swap them out?
    The switch on the brake pedal turns off the cruise control when the pedal is pressed. The turn-off switch cannot make the car accelerate. I see no point in replacing it.
    What happens when you turn off the cruise control using the stalk lever? The stalk communicates with a module.
    BMW MOA 696, BMW CCA 1405
    Jul 2004
    Houston, TX
    36 Cylinders
    What if the cruise system doesn't know you are pressing the brakes (from a faulty switch) and the brakes slowed the car down, so cruise tries to compensate?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2003
    Seattle
    99 M3
    +1.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    +2. It’s easy to replace just pull the locking ring out first and it comes out easy
    Oct 2012
    Louisville, KY
    I hadn't thought of that. The system would have to be turned off using the stalk.
    Oct 2012
    Louisville, KY
    ... might be a switch related to the brake pedal... How difficult is it to swap them out?
    Views under the dash:
    https://www.bimmerforums.com/forum/s...1#post28258131
    Instructions:
    https://www.bimmerforums.com/forum/s...6#post28358366
    https://www.bimmerforums.com/forum/s...0#post30006910
    This DIY has removal of dash panels and switch bracket, not necessary:
    https://www.pelicanparts.com/BMW/tec...eplacement.htm
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Vintage42 View Post
    Your idea to test it for shut off is good. The clutch switch should turn it off as well.
    -Abel
    Feb 2004
    san diego
    ...it depands
    +3
    I'd had this happened to mine. It was the faulty cruise control switch at the brake pedal.
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Dec 2013
    USA
    Quote Originally Posted by MORRIE View Post
    Quote Originally Posted by z3forlife View Post
    Quote Originally Posted by nevan View Post
    +3
    It turns off at the switch and the clutch. I thought it should turn off at the brake as well. Is that a mistake?
    Feb 2014
    Galt,CA
    2002 M Coupe
    Nope, you're absolutely correct, it should shut off the cruise control if you touch the brake. Time to replace the brake light switch!
    Marty
    Dec 2013
    USA
    Quote Originally Posted by MartyBtoo View Post
    Marty
    Thanks Marty. I think you are right!
    Dec 2013
    USA
    Just took a look in the garage. Brake lights are not even coming on.
    Anyone know where I can find the brake pedal switch part number for a 1999 Z3M roadster?
    EDIT: I think the part number is
    61318360417 but double check before trusting me if reading this thread for your own car.
    Looks like a fairly easy swap (famous last words lol)
    Feb 2004
    san diego
    ...it depands
    p/n 61318360417
    It's fairly an easy task once you reach the switch...
    - Zach
    Dec 2013
    USA
    p/n 61318360417
    Thanks for the part number confirmation. I already ordered it. Good thing I have a second car.
    I saw the directions Vintage42 posted. Looks simple. A guy in a video said dont worry about breaking a tab off while removing it since you are replacing it anyway.
    Oct 2012
    Louisville, KY
    ... A guy in a video said dont worry about breaking a tab off while removing it since you are replacing it anyway.
    You saw that here:
    https://www.pelicanparts.com/BMW/tec...ake_Switch.htm
    And you really get to crush the switch here:
    https://www.bimmerforums.com/forum/s...6#post28368906
    But if removed correctly, I don't think anything needs to be broken:
    Because it is designed to come out easily intact:
    This says breaking it out may bend the bracket. That would mess up the alignment and adjustment of both switches on the bracket:
    https://www.bimmerforums.com/forum/s...5#post25267405
    Dec 2013
    USA
    You saw that here:
    Thanks a bunch for the links. I dont plan on breaking it to get it out but in the video I think the guy just snapped one of the side clip things and then it came out easy. I will try to do it right though
    Aug 2012
    Kansas
    Once you see how it comes out it will make it easier to install the replacement.
    Dec 2013
    USA
    I attempted it today but I'm almost working with 1 hand due to a temporary injury so I will have to try again in a few days. I had to remove the upper panel to get a better view. I was good at sliding the plunger and red cap forward but had trouble getting the switch out. I will wait till my hand heals some more then try again. Other than breaking the switch does anyone have any hints to unsnap it? It may have been in there for 20 years. Plunger does come out so red cap comes loose. The directions on that link say it should fall out but I believe there are retainer tabs holding it in place. Wondering if its possible to pull the plunger all the way out.
    Edit now after looking at a picture I see to squeeze the retaining clips in the front not from behind. Ill take another shot at it soon.
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    FWIW I dug into my ancient history to find a link describing how I found a way to NOT replace the brake switch. I was using 2015 vintage Pelican Parts instructions and they were very misleading. This thread might be informative and help you avoid some trouble, it contains a lot of good advice (none of it from me :-) )
    https://www.bimmerforums.com/forum/s...ighlight=brake
    Dec 2013
    USA
    Quote Originally Posted by JustinHalverson View Post
    Thank you. Cant hurt!
    Dec 2013
    USA
    I got it! If I was working with 2 healthy hands it would have been a little easier. I was not having a problem sliding the plunger and red cap forward but I had problems unsnapping it from the bracket. I grabbed the plunger and cap in a pair of pliers and just started wiggling it gently till I heard a click then it came free. It did not break but even if it did that would not have mattered. Putting the new one in was easy. Works as good as new now.
    Thank you to everyone that responded to my questions especially the folks that posted links with pictures.
    It probably can be done without removing the upper panel but because the view is so limited it did help me to remove the upper panel. I also noticed I had 2 screws missing from that upper panel. I will have to search them out or maybe Lowes will have a comparable size.
    Aug 2012
    Kansas
    Ace hardware stores usually have a nice selection of odd fasteners in standard and metric
  1. cruise control issue
    By selnashar in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-22-2007, 03:12 AM
  2. Cruise Control Issues 95 325ic
    By Camano Cabrio in forum 1991 - 1999 (E36)
    Last Post: 08-02-2005, 12:32 PM
  3. Cruise Control issues
    By smurfless in forum 1992 - 1999 M3 (E36)
    Last Post: 06-01-2005, 05:05 PM
  4. Turn signal,rear lights,cruise control issues???
    By Johnnyvolvo in forum 1983 - 1991 (E30)
    Last Post: 09-03-2004, 06:05 PM
  5. Brake Light Ground - Cruise Control Issue
    By CC Rider in forum 1983 - 1991 (E30)
    Last Post: 08-09-2004, 04:01 PM
