Hi guys my e46 lost compression in cylinder 5. The car did not overheat or anything. Probably due to bad rings. This engine needs to be rebuilt. I do not want to part out this car, so maybe someone on this forum with more time and expertise can enjoy this car once again. I will be happy to answer any questions you may have with honesty.
Call or text : Nine73-two two two-6seven27
260xxx
Cooling system was replaced this past fall.
Tires and wheels are good
Driverside doorlock is shot.
I did the rear rotors and pads, The fronts will be included.
