Results 1 to 12 of 12
Thread: 90 735i e32 alternator help
    Jun 2019
    Post falls
    1990 735i
    Hello, alt failed got new 1, that didn't come with pulley. Try to take off pulley on old one, got 24mm bolt off but can not take the pulley or fan off. Please help
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    See Figure 3 and the accompanying text: https://www.pelicanparts.com/bmw/tec...Alternator.htm
    Richmond, Virginia
    '88 735i, '06 RSX
    Quote Originally Posted by Mazor tazor View Post
    The nut securing the fan is a royal pain to take off, I paid a mechanic 10$ to take it off because I was afraid of destroying it or rounding it before it came off.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    here is a parts view, if the bolt is off, probably #25 is binding https://www.realoem.com/bmw/enUS/sho...diagId=12_0526
    There is a repair kit aka mounting kit available. example, double check in realoem with your VIN https://www.turnermotorsport.com/p-7...uine-bmw-part/
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    A bit unrelated: what does #2 "Fan wheel" do?
    Jan 2005
    Japan
    Looks like a fan wheel to cool the alternator, fresh air comes thru small opening in the bumper https://www.realoem.com/bmw/enUS/sho...diagId=51_0591
    connected to these parts https://www.realoem.com/bmw/enUS/sho...diagId=12_0162
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    I had seen the duct that goes to the alternator but I didn't know it was actively cooled with a fan. Neat.
    Jun 2019
    Post falls
    1990 735i
    Dope, thanks fellas. I'll check it out tomorw after work.
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    This video may be useful. It's from an E30 3 series, but it also has a toothed rack and pulley.
    Jan 2005
    Japan
    Here you can see the airflow nicely, the older version like on the M30 and M70 pulls their air out, that fan pulls the cool air coming from the duct thru the alternator, that is in German called Topfgenerator = einflutige Durchlueftung = pic on left, scroll down where the airflow is shown.
    The compact version like on the M60 and on my E36 M3 is shown on the right, Compact Generator, zweiflutige Durchlueftung.
    The compact generator is cooled by two internal fans because of the higher specific power - which also means more heat. The two air streams enter axially through openings in the drive and slip ring bearing plate and out radially through openings on the circumference of the housing.
    https://www.kfztech.de/kfztechnik/te...-generator.htm
    Nov 2007
    SF, bay area
    94 740, 74 wagoneer
    put it in the freezer for a few hours... or dab some pb blaster between the pullley and shaft.
    Regarding the air cooling, yes these engines are well designed , as most US manufacturers are taking air from the rear of the Alt which is close to the exhaust manifold... not too smart to chill electronics with hot air
    In fact after some body work or brake work the people are the shop are more likely to forget to reinstall the duct from bumper to the manifold at the rear of the Alt, time to check your set up
    Jan 2005
    Japan
    Quote Originally Posted by letank View Post
    sometimes the ducts are missing, yes. Also it might be good to sometimes clean the ducts and check the air inlet duct at the alternator. I recently got a used alternator out of a parts E36, that inlet duct was half clogged with leaves, dead insects and dirt.
  1. 1988 735i (e32) Manual Transmission - Problems - HELP!!!
    By Nikhilrt in forum 1988 - 1994 (E32)
    Last Post: 01-07-2009, 07:44 PM
  2. WTB Water Valve/Heater Valve for 90 735i e32 M50 engine
    By Hellrot318is in forum BMW Parts Wanted
    Last Post: 12-19-2008, 03:03 PM
  3. 90 735i sunroof switch help!
    By Hellrot318is in forum 1988 - 1994 (E32)
    Last Post: 07-06-2008, 09:28 PM
  4. Need Help. '88 735i E32
    By mosetd in forum 1988 - 1994 (E32)
    Last Post: 08-24-2007, 12:16 AM
  5. Help! 735i E32 Throttle or engine management problem
    By JC32 in forum 1988 - 1994 (E32)
    Last Post: 01-12-2007, 05:56 PM
