Results 1 to 25 of 46
Thread: 86 325e starts but won't keep running
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    I'm bringing one back to life after fifteen years. I installed a new fuel pump/filter, old one froze. I've got it starting consistently but it only runs for a second or two. It will start twice then you have to let it rest for a few minutes and it will start twice again. Has anyone else had a similar problem? Thanks for the help!
    Oct 2003
    Seattle
    99 M3
    Subscribed, we have a similar issue.
    Starts, runs, idles, then when warm it dies.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    tennzguy, the sensors in the transmission bell housing (driver's side) are good? yours fires so one is good but I would check them both to see if they read good. and since it only starts than dies, I would check to see if your fuel injectors are spraying. its starting because the one on the passenger side of the intake manifold, the cold start injector, is firing. its not staying running because the others are not spraying which could be from the sensors in the bell housing.
    No e30s again.
    Mar 2010
    Abilene, TX
    1986 325e
    I had the same issue from a car that sat for a year. It was stuck fuel injectors from old gas. I pulled the injectors, cleaned them, and reinstalled and was greeted with a steady idle. Pinch the fuel return line and see if that keeps it running. I spiked my fuel pressure over 100 psi to keep it running.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Quote Originally Posted by Tennzguy View Post
    Update, boot cracked between afm and throttle, dirty contact on afm, see pics. I'll fix them and see how it does!
    Sent from my SM-N960U using Tapatalk
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Quote Originally Posted by jbontke View Post
    Good pointers, I'll try that next.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Quote Originally Posted by superj View Post
    I'll check them. Thanks for info!
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    I took the lower sensor loose and tested pins where it plugs in, I get infinite resistance no matter which pics I test. I'm reading it should be between 500 to 600 between two of the pins. Looks like a bad sensor to me! I'll test the other next, it should test good because I have good spark. That should further prove if the one is bad.
    Dec 2005
    No e30s, again :(
    Sounds like a plan
    No e30s again.
    Oct 2003
    Seattle
    99 M3
    Part number wise, they are the same sensor.
    Dec 2005
    No e30s, again :(
    you can find them on rockauto and some other sites for decent prices, also
    No e30s again.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    I'm looking around now. The top sensor tests okay, the bottom doesn't. The bottom one plugged into the rear plug. Does anyone know if the bottom one is for fuel? I haven't quite mastered all the resources for this car yet and appreciate all the help I can get!
    Dec 2005
    No e30s, again :(
    I cannot remember which is which but I know one of the holes in the bell housing has an A and one has a B which goes to one of the wires but since I am at work and cannot remember which, I hope someone else comes along to answer. the Bentley manual tells which one goes to which hole.
    one wire tells the ecu when the engine is at tdc so the ignition works properly and the other tells the ecu something about spraying the fuel. look in the hole in the bellhousing that the bad sensor sits in and have someone crank the engine over. you need to look for the little tang that the sensor reads. its just a piece of metal sticking off the flywheel. if its missing than your new sensor won't help. its really common for that tang to come off.
    my 86 was missing it. I ended up pulling the flywheel and tack welding a replacement on. some people drill and tap the spot and then thread a bolt in which they grind down to the right length but I didn't have a tap set so the ol welder came out
    No e30s again.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Good comments, thanks for the info about the tang. I will definitely check it.
    Dec 2005
    No e30s, again :(
    the e motors spray fuel differently than the I motors. the I motors spray 3 injectors at a time and the e sprays all 6, if I remember right. its odd because even though the e opens them all at the same time, it gets amazing as mileage for being put into use in the very early 80s.
    No e30s again.
    Mar 2010
    Abilene, TX
    1986 325e
    The E models has a cold start injector on the end of the intake used for cold starts. I think they are DME 1.0 and 1.1, while the I models uses DME 1.3 and it should spray all 6 injectors (correct me if I am wrong) because the DME fires the injectors in batch (two sets of three injectors) not sequential.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    No fire to injectors, I just put new crank angle sensor on and it made no difference. The car will start off the cold start injector but not keep running. I've fixed vacuum leaks and cleaned electrical connections. Any help is much appreciated. I don't have money right now for Bentley manual.
    Dec 2005
    No e30s, again :(
    That other sensor? Did you get it replaced
    No e30s again.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    No, could barely afford the one. The other tested okay per the test I found.
    Dec 2005
    No e30s, again :(
    Oh, swap them and see if it changes anything.
    Was the tang on the flywheel?
    No e30s again.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Didn't check, I'll get wife out after awhile. Definite no fire on injectors. Cold start working fine. I tested yesterday with noid light.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Motor turns over too fast to spot it. Turn with wrench on crankshaft?
    Dec 2005
    No e30s, again :(
    Its probably not there if you didnt see it. If its an auto you can pull the cover off the bottom of the bellhousing and look more easily. If its a stick, the cover from the front of the bell housing bottom comes off. Its connected to engine and trans
    No e30s again.
    Dec 2005
    No e30s, again :(
    Lets you use a screw driver on the flywheel teeth as a lever to turn slowly
    No e30s again.
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    It's a manual transmission. I see the cover with four bolts going up and six or so hex head bolts going back. It looks like I have to remove hex bolts too? I'm off tomorrow so I'll tackle it then and report back. Thanks!
  1. 86 325e starts but won't keep running
    By Tennzguy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-14-2019, 09:01 AM
  2. 86 325e Starting issues/ Won't idle/Dies
    By mischief3003 in forum 1983 - 1991 (E30)
    Last Post: 04-21-2010, 08:53 PM
  3. E38 starts but won't stay running (jinxed myself)
    By sdmike1 in forum 1995 - 2001 (E38)
    Last Post: 01-29-2010, 11:19 AM
  4. HELP! 86 325es starting/ignition issue???
    By 86red325es in forum 1983 - 1991 (E30)
    Last Post: 05-11-2009, 06:41 PM
  5. 89 535i starts, but won't stay running.
    By Ramm328 in forum 1988 - 1996 (E34)
    Last Post: 03-20-2008, 02:52 AM
